Ok I've been having problems with my brakes for sometime now with shudders and squealing brakes. I have tried all different types of pads an had the rotors machined. I thinking of upgrading the rotors to a slotted or cross drilled. Which am I better off going with ??? Any help would be awesome
CAM'S VY PHREDDIFIED AND LEATHERED!
http://forums.justcommodores.com.au/...w-leather.html
Go slotted, drilled tend to crack.
I have slotted and dimpled - apparently dimples do nothing but look weird though.
Can't say I've ever had any brake fade after changing.
Ok the only thing I really concerned about is the sqealing I've had enough of it
hey man i had the same trouble so i got some DBA slotted and crossed drilled rotors with bendix heavy duty break pads... well worth the money i reckon and you can easily feel the difference in the brakes.
heres the website if you wanna take a look and i got the gold street series... they look pretty sweet on the car as well
www.dba.com.au
Any new rotors will be an improvement, even plain (ie no drills,slots,dimples etc). Machining rotors is a waste of time imho. Standard rotors, are fine for everyday driving - but don't skimp on the pads (bendix ultimate rock my world).
Another thing - Ever since my VS (4 cars ago) I don't trust anyone with a rattle gun to tighten my wheels nuts. Ensure correct tightening procedure on your wheel nuts to prevent rotor warp / brake shudder.
"You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
yeah get the right pads... i dunno what the dude i bought the car off was using but they shredded the rotors nice and quick
ok well im picking up a set of slotted rotors in a couple weeks and i plan on getting the bendix ulitmate pads so ill let you know how i go. thanks for the help.
The ultimates are OK, but in the good version (DB1344 Police Spec) are hideously expensive!!! QFM HPX is a Bendix Ultimate equivalent performance wise, but with less dust and rotor wear, and $79 per set front or rear, and come standard as the police spec DB1344 version, not DB1331.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
What's the difference ?? Just the dust ??? O don't mind cleaning every so often as long as there no f**kin noise between the db1331 an the db1344
I found considerable noise with the "police spec" pads fitted - removed and fitted bendix ultimate after 12months - has been for me a much quieter pad with better pedal feel.
I've got slotted rotors front and back with standard Holden pads and the brakes work well with no squeeling. I was going to try the AC Delco pads Holden sell next time around as I was told they are good.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
check out the new repco catalogue.they have 2 discs,pads and brake fluid for $99.(front or rear) might be worth trying out your discs are probably warped.it's a good price for what you get and should fix the problem
Make sure you replace the rotors and pads at the same time. New pads on worn rotors will lip the pads which will squeel, and will still squeel if you replace the rotors afterwards
Yea thanks for that
Di replacing the discs and pads stop the shuddering??? because I also had to rplace the bushes on the z bar and 1 strut that had a broken shocker and the strut bearings no more shudder now
If you get new rotors I would not recommend bendix ultimates as many users will confirm they will eat your nice new rotors.
For all 8 cylinders...
Alot of people say the bendix are the best. ????
contact gslrallysport on this website. GSL RallySport
they will have rotors and pads. their pads are way better than bendix.
just bought a pair of performance pads from GSL so shall see how they go. god i hope i dont get any more noise !!!
