Results 1 to 12 of 12
Thread: thermo fan not shutting down
    VY SS UTE
    Jan 2011
    SE QLD
    Default thermo fan not shutting down
    Hi all,
    Have had an issue after pulling up at home yesterday in my ute, thermo fan was still running after I turned ignition off.... Couldn't work out the prob so undid the battery. Went back to start it this morning, after re-attaching the battery terminal the fan came on again instantly.
    Had a read through several forums to try and diagnose the problem. Most posts were saying it was a relay that needed replacing...
    Went and identified the relay that when pulled out would shut down the fan and drove down to Supercheap to pick up another one ( It's the 5 lug engine cooling fan relay 1 in the owners handbook) . Upon installing the new relay the problem hasn't gone away...
    I suspect it could be something else, perhaps a dodgy wire somewhere?, coolant thermostat?
    Has this happened to anyone else and did you find an answer before booking it in for some professional help?
    Regards,
    SS Manual.
    VS Clubsport series I, VY II R8 Clubsport
    Jan 2008
    Sunbury, Victoria
    Its normally the relay because Holden even released a Techline on this one as they had heaps of this occuring!
    By chance did you start the car and switch it off again, the BCm may have hung up too locking the fault in.
    Richo
    Only Milk and Juice comes in 2.0 Litres!!!
    VY SS UTE
    Jan 2011
    SE QLD
    I did try restarting and running the engine the first time it happened yes, probably ran it for about five/ten seconds. Didn't sort the problem so went about undoing the battery terminal after that.
    You say it's a common fault Richo, the new relay hasn't seen any difference with the issue.
    With the BCM "hanging up" do you mean that it has saved it in its memory to keep the fan running non-stop?
    If so, would I having undone the battery terminal and leaving it overnight not have re-set the BCM, is there a simple way to reset the BCM? Will do a search.
    Thanks for your feedback mate,
    Regards,
    SS Manual.
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    prob incorrect relay , i went to supercheap to get some relays in cluding the 5 pin one and some 4 pin ones an they were incorrect ( numbering on the poles) went to a few other spare parts joints and had the same problem , most of the relays that they stock are for driving lights etc . goto an autolec or holden and get the correct relays . They arnt expensive for genuine ones from your dealer . I had this same problem !!!!
    At 43 a wealth of info , but still heaps to learn
    VY S Series 2
    May 2010
    the holden one costs the same as the ones at repco or supercheap anyway... tell em which one it is and you know youve got the right relay... no point messing about only to find you got the wrong relay
    VY SS UTE
    Jan 2011
    SE QLD
    Just had a look at the numbering on the posts, 3 of them match up albeit one is an 87a the other an 87.
    The other two are out, with the original one stamped 98, supercheap one stamped 30. The other incorrect post the original is stamped 30, supercheap one stamped 86.
    Will pick up the correct replacement relay on Tuesday and fingers crossed the problem is no longer.
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    So did it fix it?? Coz I just havin same problem as
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    VY SS UTE
    Jan 2011
    SE QLD
    Quote Originally Posted by Claudy View Post
    Yes, fixed it instantly.
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    Had same prob in my vz sv8, disconnected the thermo plug behind the radiator for the day an problem solved. Seemed to be plug wasn't fully pushed in allowing moisture to bridge the gap with igniton off. 2 weeks later hasn't happened again.
    -Coaly.
    "Such Is Life"
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    My thermo fan is running non stop when the ignition is on, anyone know what the cause to that may be? It switches off with the ignition but runs non stop as soon as the engine is running? Engine is not running hot obviously, considering it starts as soon as the car does too. Perhaps a temp sensor somewhere?
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    I wouldn't be too worried unless it stops and engine gets hot, or keeps going when engine is off. Think of it as a pro-active fan, but yeah makes you uneasy when there is something not working as it should. Does it kick on with the car off/ignition on? Have you tried it on a cold morning?
    "Such Is Life"
    mx kid's Avatar
    mx kid is offline 5th pinned
    VXII CLUBSPORT
    Apr 2009
    Perth, WA
    ive had the exact same problem in my VS ute about 6 months ago. think its an aftermarket thermo but it was the relay that caused the problem.
    i just blew another one last nite changing the battery, must of shorted it out. ive got a switch inside the cabin to manually turn the thermo on and off. i switch it on all the time. better safe than sorry.
  1. headlights staying on after shutting the car off?
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2010, 12:48 AM
  2. VX engine just shutting down.
    By Craig151 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2010, 09:50 PM
  3. VS Drivers door not shutting right
    By FstStig in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2009, 09:45 PM
  4. VN SS shutting down
    By snapey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2008, 07:13 PM
  5. auto windows shutting
    By theburna in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2006, 11:10 AM
