car overheating when i'm driving along and have to stop for a while.gauge goes back to normal but goes back up again. No visible leaks,have put in coolant but not sure enough. Now lcd centre display shows nothing. Help!
How long since the system was flushed?
could be thermostat... maybe a blocked radiator or something
lol, your dash isn't rooted is it?
Mine used to do this about 2 months ago - turned out that the thermostat had packed it in.
Take the car to a radiator/cooling specialist and have them pressure test the cooling system. No value in just trying to guess what the problem is - might result in you cooking the engine. Very expensive then !!
Benboy is right i'd probably take it to a specialist, could be a number of things. Radiator cap, thermostat, heater tap, water pump but also make sure your using the right coolant as there are a few different types.
