Results 1 to 9 of 9
Thread: Cold Liquid Dripping onto Left Foot
    VY S Pac
    Mar 2010
    Default Cold Liquid Dripping onto Left Foot
    Hi Guys,
    Just recently a very cold liquid (suspect air con) has been dripping onto my feet from under the dash whilst driving.
    Any ideas?
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    my VN did/does the same.. Air con drain pipes are probably clogged. You can get at them from under the car, just forward of the transmission (in my car anyway, I'm assuming it's pretty similar) or the hard way like I did by taking the whole dash out
    as a side note, i already had the dash out to replace the a/c fan.. didn't just jump right into it that way lol
    Dec 2009
    My VY did this a few days ago going around a corner after driving all day on a hot day with the aircon on. If it's not coolant you have nothing much to worry about as it's just condensation from the aircon unit inside the car that hasn't drained out.
    gordo881005's Avatar
    gordo881005 is offline unholy confessions
    VY V6 Storm2
    Mar 2010
    Hunter Valley
    It would be the drain pipe, just whack some high tensile wire up its guts and you can usually unblock it. mine had a hornets nest in it last year. but is all good now.
    I’m held accountable
    For every idle word
    Curse the idle words
    VY S Pac
    Mar 2010
    Quote Originally Posted by gordo881005 View Post
    Thanks for the replies.
    How do I get to the Drain Pipe?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by christopherVYpaul View Post
    Like nstone63 said it's underneath, near the transmission. If you have access to a set of ramps, then get the car up on them and you can get under no worries. Otherwise, maybe park over a steep driveway or similar and try to get under that way. Don't just jack it up and get under unless you have a death wish!
    VY s2
    Jun 2010
    Camden NSW
    hey as evryone else says it may be air con, but i had this happen few months ago and found it was the diamond shaped rubber grommet in fire wall in drivers foot well that was leaking water after bit of rain etc, just another possibilty
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    As Soop said, the drain is near the transmission. If it's like the earlier models, t is actually in the top of the transmission tunnel above the transmission. A rubber drain pipe runs from the evaporator down through the transmission hump. I'm not sure if the set up is like the old VR had, but that used a wire insert to keep the drain pipe from collapsing. The pipe would then block up with mildew and other crap that formed around the insert. If the later models use the same setup, you can reach up and pull the wire insert out of the drain pipe and the condensate will flow out freely. Clean up the insert and re-insert it after all the water has drained away.
    vy ss sandman 5.7
    Feb 2009
    Up North Wa
    i found usually its your evaporator blocked and freezing up causing it to drip cold fluid.
    Vy ss sandman, bringing back the past!
    [CENTER]
  1. VS v6 coolant dripping from trans...
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2010, 03:21 AM
  2. coolant dripping from sump?
    By pillzor in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2010, 02:30 PM
  3. Air Con Water Dripping?
    By mbvp73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2010, 04:47 PM
  4. VR leaking water next to left foot
    By RedAdare in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2007, 01:41 AM
  5. dripping
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 05:37 PM
