Results 1 to 18 of 18
Thread: can someone fill me in about air bags please
    VY S UTE
    Jan 2011
    brisbane
    Default can someone fill me in about air bags please
    hey guys in looking into putting a full selt of bags on my ute but i know nothing about then lol mainly for work but abit of fun aswell but ive being reading a few people and some say that they are allowed and some say they arent in brisbane bit confusing. would someone be able to fill me in alittle about this?
    cheers
    Vy Series 2 Utility
    Nov 2010
    Gold Coast
    Bags are illegal in Queensland except on the rear of a utility to allow for heavy loads. You have to get an engineer plate on your vehicle but I highly doubt you will find someone to fit them unless you know them. Closest thing you can do legally is air shocks that Monroe make, they are available through repco.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    You can also fit poly air bags which fit inside the coil spring.
    I have them fitted to my senator, post 72, page 3.
    My HSV VZ Senator Barbados blue
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    Quote Originally Posted by uteaddict View Post
    Since when:
    Quote Originally Posted by Queensland Transport - Light Vehicle Modification Pamphelt
    Airbag or air pressurised shock absorber helper springs may be fitted in addition to the original suspension. However, replacing some or all of the suspension system with an air or hydraulic suspension requires specific approval.
    So that says all you need is engineering approval. Because as it is altering the suspension well from original spec, or even optional spec. Which is what is required for any "Complex Modification" in the eyes of QT.
    I aim to misbehave.
    VY S Series 2
    May 2010
    my mate just put bags in his vz although it is a sedan so im geussing there would be a few similarities
    cant get the link to work for some reason
    anyway just google
    street commodores just another sv6
    should be the first result that appears
    VY S UTE
    Jan 2011
    brisbane
    so does that mean if i get them proffesionally fitted that itll be alggod or so i needa go to a michanic and get a road worth or something
    VY S Series 2
    May 2010
    even if you get them proffesionally fitted you still need an engineering certificate... if whoever installs them has the ability to do it then youll be alright but most dont... eng certs usually cost around a grand from memory
    VY S UTE
    Jan 2011
    brisbane
    do you kno if their leagl in brissy. everyone says differnt some say u can and some say you cant
    Vy Series 2 Utility
    Nov 2010
    Gold Coast
    Quote Originally Posted by lein View Post
    They are helper springs. Which, as it says need all original suspension so it really only assists original ride height. Unless you have concrete in the boot you still run the risk of a defect. So as both of us have said, you will need an engineer plate/certificate to have them replacing original suspension.
    lein's Avatar
    VZ Ute
    Dec 2010
    Tropical QLD
    Yeah for load assist bags you retain the original springs and shocks. But if you're installing fully-sick-dropped-on-it's-belly air bags all round it's a major modification from standard is what I was getting at. I suppose it all depends all on what sort of bags the OP wants to install.
    I aim to misbehave.
    VY S UTE
    Jan 2011
    brisbane
    oh alrite is it worth the hassle lol. if you have a look at my ute, i wanna keep the same ride hight as it is now but i wanna be able to lift or for when i go up drive ways but then be able to drop it back down if you kno what i mean ?
    Vy Series 2 Utility
    Nov 2010
    Gold Coast
    not worth the hassle in my books... decent bag setup $3000 + engineers plate (up to $1000) + the chance of defect if an officer wants to book you for it.
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    I would think you'd need a minimum budget of $4k including engineers report - and don't expect your insurance company to agree that it is fully sic for going up driveways.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    Jun 2005
    Brisbane Bayside
  15. #15
    Vy Series 2 Utility
    Nov 2010
    Gold Coast
    VY S UTE
    Jan 2011
    brisbane
    yeh i was thinking sumwere around the 5 grand mark max i just want to be able to raise it and then drop it back down to the ride height its sitting at now
  17. #17
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    Quote Originally Posted by blair44 View Post
    Pedders Air Assist - Make light work of heavy loads with Pedders Air Assist - Pedders Suspension
    have a look through this info from pedders might help ya~!
    rarther than a heavy load you could raise the car with this too higher or heavy load and have same ride height
    and the kits add to suspension and do not take away from it
    so shouldnt need a mod plate im pretty sure...
  18. #18
    VY S UTE
    Jan 2011
    brisbane
    yeh i think that those are them ones that go inside you coils for when you have a load on and put it back up so the rear end dosnt say
  1. Boot lid fill and respray
    By 1FATVZ in forum Spray Painting and Panel Beating
    Last Post: 05-09-2010, 08:58 PM
  2. Night fill work
    By Spaced in forum The Pub
    Last Post: 23-03-2007, 12:40 PM
  3. cant fill fuel tank
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2006, 07:28 PM
  4. 35 Litres to fill up a Commodore?
    By SIXAPPEAL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-06-2006, 02:35 PM
  5. What's your record petrol fill?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2005, 09:39 PM
