Results 1 to 11 of 11
Thread: Excessive fuel consumptiom
    VY ute 3.8l
    Jan 2011
    Broken Hill
    Default Excessive fuel consumptiom
    I have a VY ute, 3.8l that uses loads of fuel. Both petrol and gas. I average about 15l/100km and when towing 23l/100km. Auto trans drops into top gear at 125kmph. Is this a problem or would I better changing the diff??
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    There are a few things to consider before just changing the diff.
    First, what ratio is the current diff? I don't know what was fitted to the utes, but the VY's had a range of diffs, from 3.07, 3.46, 3.73, 3.91. The higher the number, the lower the diff ratio and the greater the number of revs for a given road speed.
    Second, does it drop into top at that speed even with a light throttle? Have you had the trans serviced and what condition is it in?
    Third, what type of LPG system do you have - the old fashined mixer type or far better injected system? The old single inlet set up can cause plenty of problems if it is out of tune.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Apart from the gearing, when did you last change the engine air filter element? These clog up easily in normal use and you will use more fuel if running with a clogged air filter. I would be changing the filter at least every 12 months and possibly more depending on driving conditions you encounter in your area. The filters for the VYs are very cheap to buy and easy to install.
    VY ute 3.8l
    Jan 2011
    Broken Hill
    Hi Calaber, Thanks for the reply. As I primarily use it as a tow vehicle it does very few k's per year. I'm not to sure of the diff ratio, but will endeavour to have it checked out. Also I don't think the trans has been serviced as its only done 75,000km. The gas injection was fitted in Adelaide from new, so I think it should be OK
    VY ute 3.8l
    Jan 2011
    Broken Hill
    Thanks Sean880, Yes, you're probably right about the filter. I don't do many km's per year, but it can very dusty out here and I will change it and see if there's any great change. Thanks
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    when was ur oil, spark plugs/leads, fuel filter changed last? make sure ur tyres are pumped up correctly
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VY ute 3.8l
    Jan 2011
    Broken Hill
    ta WogBoyz, I'm having everything replaced late next week. Then we'll see if it's VY or a lemon!!
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Just my 2bobs worth , i have a vt it was using fuel like there was no tomorow i did everything leads , plugs , filters ect ect even took it to holden ,no one could fault it also had some power loss , this went on for ages . Anyway one day i was stuffin round lookin at shit an i noticed one of the battery terminals wernt looking that flash , so i shot down the auto shop an got two brand newys an threw em on , well blow me over it sorted out the damn car , heaps power again and ran on the smell of an oily rag . Just what happened to me .
    At 43 a wealth of info , but still heaps to learn
    VY Commodore S1 A4 Executive & VY ute A4
    Jan 2011
    My VY commodore has a similar issue with fuel consumption..I'll checkout the air filter and battery terminals in the morning...
    BTW this is my first post on here..woo hoo
    madcowbeavis is offline Not your average cow
    VY Series 2 - 25th Anniversary
    Oct 2007
    In addition to frequent oil changes, ensure that the correct oil is actually being used. Recently one of my other commodores (i.e. not my main drive) dropped from ~12L/100km to ~9.5/100km's just from changing the brand and type of oil used. As the servicing had been done by myself over the past 2 years, I can confidently say that the only difference was the type of oil used.
    Vs Berlina
    Mar 2009
    What oil did you use that got the gains????
  1. excessive fuel line pulsing
    By hsv_kid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2010, 07:22 PM
  2. Excessive fuel consumption
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-03-2007, 05:59 PM
  3. Excessive fuel use
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 10:00 PM
  4. excessive fuel consumption (92 vp)
    By tung in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 11:01 PM
  5. Excessive Fuel Consumption
    By bushy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2003, 08:51 PM
