Hey
I got defected for being to low and need to put the original springs back in my VY ute.
But having trouble with the rears. I cant get them in. have removed the shock but still and inch or 2 long. There seems to be no room for Spring compressors .
Any Ideas?
Mike
dont worrie just needed to put a bottle jack on the hub and some wood in the guard and force it down
theres under bolt u can undo to get it to drop down a bit. not sure of name but it goes from ur control arms to ur rear sway bar.
Make sure your Hand Brake is not on, Whilst installing the rears either. Release the hand brake and the cradle drops a little.
Cheers,
Super6
That'll teach you to drive a car that looks like a dog scootin its arse.
Just get a mate to stand on the hub.
To get maximum droop you need the hand brake off and the gearbox in neutral (man or auto) and you may need to also disconnect the rear sway bar.
You still may need a big screwdriver or pry bar to slip the original springs back in.
Is this only temporary or are you going to lift the car to a legal lowered height permanently.
Because it may pay to buy the right lowered springs now, fit them and be done with it.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
if you also leaver out the drive shafts a bit out of the diff that will give you an extra 2".
