Results 1 to 8 of 8
Thread: Vy SS Ute - Not cranking
    VT CALAIS
    May 2006
    Question Vy SS Ute - Not cranking
    Hey all,
    So i tried starting her on thursday and nothing ( no cranking , just silence ). so i checked my battery volts had 12.3v. So pulled out my charger and hooked up to try it on engine start mode, and she fired up. Rechecked volts and had 13.5 - 14v while in idle. Checked temination on battery posts all tight.
    So battery was a cheapo 7 plater but 6mnths old, thought maybe me battery wasnt big enough.
    so today im at the shops and go to start to come home and nothing again.
    So thought hey theres suppercheap ill buy a century heavy duty $150 banger. Put her in and nothing, so i parralell up new 1 as well as old 1 and nothing. i know the leads were inherited from some old bomb so i get me a set of good leads $45 and try again and nothing.
    So $100 later the tow truck gets me home and i try with the engine start like before and nothing. I inspect the key contacks all clean as well as spare key and still nothing.
    Is there a cyntrifical switch in the starter motor that maybe stuck or is it new starter?
    N e ideas would be welcomed..
    VK Berlina
    Jun 2010
    Quote Originally Posted by fr1day_vt View Post
    Hey all,
    maybe an auto elec should have a look? cos when you moved the battery out it can shut down something electrical.i know these things are so sensitive when it comes to touching anything electrical and it can shut your ecu down crap blah blah stuff like that...sorry i dont know much really when it comes to efi cars
    VY S Series 2
    May 2010
    ive disconnected the battery in mine before and it might run rough for a few seconds till the ecu "remembers" i geuss... smothed out after that so i dont think that would be a problem
    VT CALAIS
    May 2006
    Default Ta
    I cam out the next morning and fiddled with the outer ring round the key hole just wondering it was making good contact and tried turning her over again and hey presto, just wondering if it was the ring,or time she sat indoors after the rain( maybe moister related).
    Now just wondering if I'm running on borrowed time cheers lads for the input.
    P.s bring back the drought
    VT CALAIS
    May 2006
    Default damn it
    Nah went to get some supplys in our empty stores due to all the crazies stripping it bare for the floods, and no go again. Pretty sure its the solenoid on the starter or the starter itself, but due to no clicking must be the solenoid.
    Might go try the hammer trick but the motor is tucked under exhaust manifold maybe i can hit her with a drive. but if dont work theres another $100 for a tow truck which would of payed for the damn starter motor including the other tow.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    check that the little terminal on the starter is pushed on all the way (this is signal wire)
    and also while your there the big nut that holds main battery cable onto starter
    -dont break the big nut off starter just see if big wire is loose
    -the nut only sort of nips up if its loose
    yeah try tapping the starter motor to see if starts up...
    need to check battery voltage while cranking it over (or trying too)
    with a new battery and/or jump battery aswell
    if voltage still drops when turn the key (10volts or less) then starter solenoid is jammed or not making contact correctly
    also try seeing if the ign relay clicks when ign on, then check if starter relay clicks when key put to crank
    this will eliminate dodgy relays all thats left is starter....
    VT CALAIS
    May 2006
    Thankyou all for the help, Apon returning to supermarket to the stranded girl i checked the connections from the battery all tight. I found it hard to hear the clicking of the relays from within the cabin so I jumped to the tapping of the starter. I found it hard to even see the damed starter from under exhaust but finally spotted it from under the what looked like a heat shield. Tap tap, and tried but nothing. Tap tap thump and hey presto she fired up.
    So this weekend is starter motor weekend yay, or can I recondition the solenoid me thinks for probably not and where is the best place to purchase one from (repco maybe) and what kind of damage am I looking at?
    Thanks for all the help as well
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    try an auto electricians they will do an echange and have normally got a warranty (cheapest optioni use)
    that or trade disacount through holden or repco is not too bad normally
  1. VK, cranking but no go????
    By zaczac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-07-2010, 07:46 PM
  2. Vt cuts out when cranking
    By johns496 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2010, 11:26 PM
  3. Slow cranking VT
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 08:41 AM
  4. Cranking but Not Firing
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 04:25 PM
  5. VR Slow cranking
    By CrazyDayz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:02 PM
