Results 1 to 3 of 3
Thread: VY Ute - Fuel Filling Problem
    VT
    Apr 2006
    Default VY Ute - Fuel Filling Problem
    I've got a problem with my VY Ute. Over the last couple of fuel fillups the filling pump keeps clicking out before I've hardly got any fuel in there - and I'm not talking about getting 3/4 of a tank, I'm talking getting 1 to 2 litres in there.
    I end up slowly (very slowly) topping it up to about 20 bucks worth. Takes about 5 mins to get there.
    It's only started doing this recently so I'm thinking there is probably a blockage in there somewhere. Being a ute I think the access panels are fair easy to get to from the tray - but any pointers as to where I should start would be great.
    What should I look for first, filler hose itself or a breather line somewhere?
    I took a close look at it this morning and I can see fuel foaming out from two small slots above the spring loaded flap in the filler line - that's probably a really bad description sorry.
    Thanks,
    Benniee
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    have you used a different fuel station or have the fuel station you are using changed pumps. because i found that mobil fuel stations would never like filling up my pagero because of the angle of the nozzle it would always cut out
    and at the metro i have to have it 3 - 4 inches out of the car (but the end still in) to get it to fill my excel.
    no problems with the vy though.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    is either angle of nozzle
    try holding nozzle upside down
    or try not putting it in so far
    could be air block in pumps
    one very rare one i had was that tank was already full and the fuel (mra) reader inside tank was reading incorrectly
    otherwise could be a sticking flap in the tank outlet (where it connects to rubber hose you fill it from)
    this is rare though
  1. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  2. Bad fuel economy/When should I be filling up?
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2009, 10:50 PM
  3. Gas over filling
    By VL Berlina 5speed in forum General
    Last Post: 29-08-2008, 02:38 AM
  4. Filling My VS
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 11:17 AM
  5. Fuel spurting out when filling?
    By cev in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2005, 03:11 PM
