Gday all im new here and have inherited a vy commodore and was wanting to know this exhaust system would be a straight fit to a v6 series 2.
TWIN 2.5" CAT BACK SPORTS EXHAUST VT VX VY VZ HOLDEN (eBay item 360310646685 end time 14-Jan-11 17:01:24 AEDST) : Cars, Bikes, Boats
thanks any help is welcomed.
Do not go twin on a stock V6. That system won't fit anyway.
If it is just noise you want, the I can supply you with a 2 1/2" cat back Manta system for $260. If you want it louder I can do one without a resonator for $220.
If it is performance you are after, then fit extractors, leave the standard size but replace the mufflers with straight through glass packed items.
REDBACK 2.5" CAT BACK EXHAUST VT VX VY V6 COMMODORE (eBay item 360310597299 end time 24-Jan-11 19:00:14 AEDST) : Cars, Bikes, Boats
Get that but talk to the seller about one with a rear muffler, $235 + $40 freight.
Tuffcarparts
thankyou for the information.
sorry but i forgot to outline my other plans for purchases:
1: stage 3 comp cam with retainers and pushrods to suit.
2.mace 25mm manifold insulator, 69mm throttle body, 82 degree thermostat.
3.otrcai. extractors of some description.
thanks any other info is ,much appreciated.
i also need information about extractors which would bolt up to the factory cats
i am handy with a welder if i have to
the stock system is dual cat.
if it helps
