Results 1 to 6 of 6
Thread: ls1 engine breather cable broken?
    Holden VY clubsport
    Jan 2011
    Default ls1 engine breather cable broken?
    hi fellas, iv got a vy clubsport with a bit of wark dont to it cam , heads ect.. i was having a look around in my engine bay and noticed at the back of the manifold close to the fire wall found a pvc tube completely snapped in half and tubes run to the backing of the rocker covers and each side, and also around the thottle body. well it make a difference and is it worth changing? heard its just a breather pipe???
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    Best to get a new one from Holdens. $80 from memory.
    Its the PCV system and is vital and can affect how the engine runs.
    Holden VY clubsport
    Jan 2011
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    yeah if that is broken you car should be idling like shit on start up for a min or 2 well mine did i just replaced the pvc hose as it was broken in the same spot.just relized this is the vy section mine is on a vx ls1 an im sure they have a different setup so maybe it wont effect the car the same. mine cost $140
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    its just so the crank case fumes dont get vented out to the astmosphere as they are harmful to the eniviroment. shouldnt do any damage but if in the unluckly case you get pulled by the epa they might have something to say in the way of a big arse fine.
    EDIT: also at WOT it will have oil coming out so if you drive like skaife you will get oil in your engine bay.
    Holden VY clubsport
    Jan 2011
    Haha just got an EPA for noise so I'll be changing that right away!!
LinkBacks (?)
  1. kick down cable adjustment broken
    By vp_commo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2010, 08:43 AM
  2. bonnet cable broken please help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2007, 05:16 PM
  3. broken bonnet cable????
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 07:56 PM
  4. Broken Bonnet Cable
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2006, 04:43 PM
  5. Broken Accelerator Cable
    By tristanwalz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 05:19 PM
