Results 1 to 6 of 6
Thread: Fan ticking (A/C off and on).
    madcowbeavis is offline Not your average cow
    VY Series 2 - 25th Anniversary
    Oct 2007
    Default Fan ticking (A/C off and on).
    Ever since purchasing my 25th Anniversary, I've noticed a ticking noise when the air-conditioning fan is on, regardless of what position the air is directed to (i.e. feet, face, combo etc) or what temperature the air is at, or whether the actual air-conditioning is on or not. The previous owner said that he had had it investigated by the Holden dealer that he had purchased the car from and had it serviced by, and they couldn't located the source of the ticking.
    Both myself and my mechanic have also been unable to locate the source of this ticking. Has anyone else had this problem? It seems to only be on Speed 1, although it may just get to a frequency at Speed 2 and Speed 3 that it's no longer audible over the rushing air.
    It's starting to drive the missus bonkers, because I always have music on when driving solo, yet she wants to talk when we're in the car together, haha.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    blower motor fan bearing
    only hear it on low speed
    pull fan out plug it in and turn it on in your hand on 1 you will hear it if this...
    else maybe a relay for fan not connecting properly like worn out on actuated side inside rely
    pull cover off rh lower dash to see if relay is source of noise
    good luck~!
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    I had this - remove blower fan (3 screws) and what i did was spray silicone lube down onto the shaft. Put it back in - all good... for about 4 weeks.
    It certainly confirms what the cause is, but I have yet to devise a longer lasting solution that does not involve a new blower motor
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    it is the a/c blower motor. It will drive you nuts.
    it is a very simple job to replace. holden will charge around $290 for a genuine replacement,
    Bursons have the same thing for $165.
    it is a 10min job to exchange it.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Oct 2007
    *Comes up for air after the holiday period*
    Thanks for the detailed responses, I will have a play around with it to determine the problem, and eventually get back to you if I find a long-term fix for the existing unit.
    Jun 2005
    Brisbane Bayside
    I was quoted $140 at my local holden dealer last week - I think there may be a difference between series 1 and series 2 ??
    I tried a used VZ blower motor (pick up free) and it was Worse!
    I tried stripping down the vz motor - and could not find a way to silence the noise - I also doubt I could get it back together l-)
  1. Ticking behind dash (no, not injectors or lifters ticking)
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 01:20 PM
  2. Ticking me off!!!!!!!!!!!!!!!!!!!!!!
    By Joey_21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2008, 01:24 PM
  3. VP Ticking
    By DavoVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2008, 12:00 AM
  4. still ticking
    By mortivivosdocent in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2006, 03:28 PM
  5. 95 vr ticking
    By brohawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2006, 09:11 PM
