Results 1 to 8 of 8
Thread: Vy s body control module
    vn ss,vl turbo, ktm 525,vs bt1
    Sep 2010
    shepparton
    Angry Vy s body control module
    Hey guys,girls , me mrs uncle decided too be real smart and see if his vy spac would float in the flood water's and sent it swimming up too 1/2 the front window , all the comp and other electrical components are fine but i took the bcm and it looks stuffed
    it wont even crank has service error up on the dash?
    will the bcm stop it from cranking completly?
    ,Do not argue with an idiot. He will drag you down to his level and beat you with experience.
    vu maloo
    Jan 2011
    Quote Originally Posted by 5LTRVNSS View Post
    yes mate,, the bcm is coded to your key and engine computer, you need that to start. let me know l may have one for you, but you still have to get id coded to your pcm.
    Sep 2010
    shepparton
    hsv-malloo
    Yeah thats what i was thinking but wasnt positive but all lead back too the bcm , due too the following
    like.....
    windows dont go up/down ,
    hazard lights continuosly on ect,
    also correct me if im wrong but a replacement BCM for a VY has too come out of a VY with the power windows and matching numbers on the caseing such as
    601-MID??
    could i have his original key re-programed for him at holden or my local mech ?(normally dose all my brand new vr-vs-vt-vx keys)
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    you can have his originally key recoded to the new BCM at holden.
    As long as you get the same level of BCM then have your ECU configured to the new bcm by holden it will work. the is low, mid, and high lvl BCM's.
    All the faults you listed a text book BCM faults.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VY keys can only be coded once, so no you cant get the original key coded to a new BCM.
    Silver Certified.
    sp001in's Avatar
    MALOO R6
    Jul 2005
    QLD
    Quote Originally Posted by RiCeY View Post
    If I didn't see "Holden Technician" under your name I would be calling shenanigans but you would know better than me.
    I've never had a old key recoded, but I've had 2 HSV keys coded to my ute. I assume they must of been new then.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Yeah a new BCM generally comes with two new key heads right through to VZ.
    VE keys are reprogrammable.
    Silver Certified.
    Sep 2010
    shepparton
    well guys replaced the BCM in it , all the lights,windows ect ect all work, but seems too have no power signal going too the starter..(has main power but nothing on the signil wire , took the starter motor apart cleand all the crap out it engages when i tested it out of the car so cant be that
    so its got me stumped ...maybe a moduel/chip on the comp somewhere or something else hideing inside the bloody thing!
    ALL IDEA'S WELCOME need this vy outa me driveway the mrs uncle is drivn me nuts~!
LinkBacks (?)
  1. Body Control Module
    By BerlinaV8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2009, 03:49 PM
  2. body control module
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2008, 08:52 PM
  3. Body control module
    By spazdan01 in forum Electrical Wiring / Questions
    Last Post: 07-05-2006, 12:30 AM
  4. Body control module. What is it and what does it do???
    By kojamoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2006, 08:14 PM
  5. Bcm (body Control Module)
    By kritterman33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2006, 10:22 PM
