Results 1 to 10 of 10
Thread: New T/B high idle
    VY11 clubsport R8
    Jan 2011
    Default New T/B high idle
    Hi Guys,
    New here hope someone can help. Fitted a new 80mm t/b with the old TPS & IAC on my Y11 R8, had a mafless mail order tune, & 21/2" high flo cats as well, already had Sureflo 31/2" single cat back system & OTRCAI..
    The new t/b came with an adapter so throttle cable has been reset & ok, plenty of slack.
    When engine off the throttle is very smooth & returns no problem, when started idles ok, give it a rev & only returns to 2000-1500rpm. If i give it a blip it returns to idle, i have even loosened the TPS & IAC with the engine running, still no good, if i turn the engine off in the fast idle state, i can see the t/b return to the throttle stop. I have also disconnected the TPS cable & turned ignition on to reset the throttle position, no good either.
    Any ideas before i head off to a local tuner next week?
    Briby
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VY11 clubsport R8
    Jan 2011
    Hey Soop,
    Don't think so, snaps back nicely with the engine off, the pedal seems a bit firmer, so i thought the spring would be alright, but i'm starting to suspect the TPS, suppose i could always put the old one back on and see what happens. Can't get any response from the seller.
    VY11 clubsport R8
    Jan 2011
    Snaps back nicely with the engine off, pedal seems a bit firmer so i thought the spring would be ok.
    Nov 2008
    Smithton, Tasmania.
    VY11 clubsport R8
    Jan 2011
    VY11 clubsport R8
    Jan 2011
    Just started it & gave it a rev by hand & it needed my help to return to idle, was looking at the old t/b & noticed the IAC port lines up with an opening in the manifold, so it looks like air is drawn in through a port above the t/b, through to the IAC, into the manifold, the adaptor has no opening to the manifold, could that be the problem?, surely the t/b manufacturer would know better, can't get any response from them.
    What are your thoughts before i go drilling a hole or porting out the adaptor.
    VY II V6
    Dec 2006
    blown vy v8 ute
    Jul 2009
    little plastic bit that goes on the throttle body between the tps ... i had this problem . tiny piece of plastic slides onto where the tps goes so it can read properly .. it will probably still be on your old throttle body .
    VY11 clubsport R8
    Jan 2011
    I know what your talking about, feels like it's magnetised a bit & sticks to the shaft, but still in the TPS, taking it to a local tuner, they think it's the IAC, needs ECU tweak to work with the new T/B.
    Thanks
  1. vy ls1 high idle!! please help.
    By victor71 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2011, 02:40 PM
  2. high idle
    By Got_Balls in forum V6 Development And Modification
    Last Post: 12-05-2008, 11:19 PM
  3. high idle??
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2007, 11:52 PM
  4. High Idle
    By VStooDie4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2006, 10:33 PM
  5. High Idle
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2004, 12:58 PM
