Results 1 to 7 of 7
Thread: What side is the drive wheel?
    VS Statesman, VY Holden Equipe
    Jan 2009
    Te Aroha, Waikato
    Smile What side is the drive wheel?
    Can anyone tell me, what side the drive wheel is on a V6 VY commodore, as I have 2 tyres, 1 new 1 1/2 worn & want to put the new tyre on the side that get the most wear? make sense? I dont want to have to do a burnout to see which tyre leaves the mark..lol.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    On a normal differential drive goes to the wheel with the least resistance.
    So if turning left the cars weight transfers to the right wheel which makes the left wheel light and therefore will spin easier.
    Opposite happens if turning right.
    If you talk to a tyre expert they will usually tell you that the left side tyres wear more than the right because most roads camber to the outside which for Australia is the left side so it is natural that most weight transfer when driving straight ahead is onto the left side of the car.
    But in all cases differences would be minimal and would usually take thousands of kilometres to show any patterns of wear to emerge.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    All the single spinners I have had spin on the right (drivers side) when going in a straight line. Also my right (drivers side) tiers always wear out faster.
    Best RPG ever
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    My Drivers side has most worn out, I can do a stand still and spin both..
    On dirt.. I can skid up the road with one bald tyre and one thats still fairly new.. and still spin both... I dont have a LSD..
    SurfWagon has a good explanation..
    P.S if you drive with responsibility ... Tyres should last years, the front tyres should be the first to be replaced. :P
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    The Left Rear is always the tyre that wears the most in "Normal" driving (rear wheel drive vehicles). If you drive in an area of lots of roundabouts its the Left Front tyre that wears a lot too, along with the Left Rear tyre. Your spare tyre & wheel should always be configured to fit to Left side of car if running Unidirectional tyres, because statistics say thats the side you will need it on.!!!!! DaDa!!!!!!!!!!
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Basically, you're turning right more often and loading up the outside wheels.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
  1. 99 VT Just got wheel aligned, now car jumps to the side after a bump!!!!?
    By gsxrdan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2010, 03:45 PM
  2. all wheel drive holden vl
    By Shetlon in forum General Discussion
    Last Post: 24-12-2009, 11:10 PM
  3. Drivers side front wheel moved forward
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2008, 11:07 AM
  4. vs making a sound from front passenger side wheel
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2006, 08:46 PM
  5. Drive Wheel Banging Noise!! HELP!!
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2006, 09:30 AM
