Noticed oil on both end's of this hose. But one end runs into the a/c compressor ?? Not sure where the other end goes as it connects to a pipe that goes to the radiator.
Item 6. Discharge hose tube. From what I can see it shouldn't have oil in it. but I honestly have no idea about how air cons work mate.
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
does your aircon still work alright? cause to me, oil in that particular line means the A/C pump is pumping its own oil out into this line, which means ur A/C pump is on its way out.
could be oil spray from Power steering pump above, wipe the area down & have another look a few days later , Air Con oil is normally a phosphorous green or blue dye type oil. this stuff you have looks like engine oil or power steering fluid.
If you suspect its aircon leaking then get someone to put die in it and drive it for a week after a good clean , then they use UV glasses to see the die if it is indeed leaking.
I suspect it will be tranny or power steering oil myself.
Right click save as . .
oil can leak from those connections in aircon hoses, maybe just give it a good clean and run your aircon for a couple of days to see if it is leaking from the hose.
Aircon seems to be working. I noticed it when changing headlight bulbs It looks like engine oil And i don't think its spraying off something as its also leaking at the top end of the connection Think ill just get that hose replaced. Thanks
Just left of it there looks to be an oily deposit aswell. Which would lead me to think that it's really an engine oil leak.
Check your rocker covers for any leaking. That hose, plus a regas will set you back over $300 easy. A clean, and a recheck a week down the track will help to pinpoint and save any unnecessary repairs.
Originally Posted by Reaper:
Originally Posted by Jecs:
I had a similar leak on my A/C hose near the compressor there.It looked exactly the same as yours does in the pic.They leak where the rubber hose and the metal connector are crimped together.The compressor oil gets pumped around through the system with the A/C gas,so if theres any leaks at the hose joins, the oil will leak out too.The A/C guy tried to re crimp the hose tighter,but it wouldnt stop leaking ,so he replaced it altogether.Just needed a regas then, and its been fine ever since.
Yeah its def that hose I did the rocker cover gaskets 2 weeks ago. Thanks for the reply's will look at getting a new hose.
