Results 1 to 3 of 3
Thread: Buzzing Brakes
    VY SS
    Oct 2010
    Ourimbah
    Default Buzzing Brakes
    Hey Guys - A little help please
    Have just fitted new Rotors and Pads All round. Slotted at the front and Drilled/Slotted at the rear. The Mechanic/Qualified (Good Friend) has done this for me.
    The Problem is (When I say problem I mean annoyance more than anything) There is a constant 'Buzzing' sound (fairly certain its coming from the rear), Like a cicada and when I apply pressure through normal braking the noise gets louder. It's always constant and only louder when braking.
    I have no idea what the noise is nor does he???
    Light travels faster than sound. This is why some people appear bright
    until you hear them speak.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Slotted rotors will make more noise that standards, sometimes changing to a different pad will stop the noise.
    Visit my Facebook page
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by Luca_VY View Post
    You do not indicate what brand of rotors you purchased.
    In my view the noise you complain of is emanating from the rotors. Both slotted and the drilled / slotted rotors can produce this noise depending upon the design of the rotor. It can be pronounced with drilled rotors - but it is dependent on design and the slot/drill pattern. It's likely that most of the noise (not necessarily all) is coming from the rear rotors which you say are both slotted and drilled.
    In my opinion you will not eliminate the noise by changing your rear brake pads because they are not the issue. You will likely need to use a standard face rear rotor if you wish to eliminate the rear brake noise entirely.
  1. buzzing noise
    By vzberlinav6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-06-2010, 05:11 PM
  2. buzzing at 1800rpm
    By cover.your.tracks in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-01-2010, 08:29 PM
  3. buzzing noise
    By freshh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2008, 11:32 AM
  4. Buzzing sound
    By enfz in forum Car Audio
    Last Post: 22-11-2004, 01:21 PM
  5. Buzzing in speakers
    By G4orce in forum Car Audio
    Last Post: 01-11-2004, 10:51 PM
Tags for this Thread
