Results 1 to 17 of 17
Thread: HELP! - Overheating issue
    Vy Berlina
    Sep 2010
    Wollongong
    Default HELP! - Overheating issue
    Hi All
    So, I was jsut driving to get some lunch, was stuck at some lights & the engine hot warning came on. I pulled over for a few minutes and let it cool down, then drove another 2 minutes back to work.
    By the time I got back to work I heard a hissing noise, popped the bonnet and found coolant leaking out - couldnt tell exactly where. Had to get back into office so locked her up and left.
    its a pretty hot day ~30 degrees.
    Im thinking that a hose has split due to heat? or could it be something worse like a blown radiator?
    Any pointers would be appreciated. Will it be safe to drive once cool? Or should I call a tow truck?
    VY Berlina 3.8L stock as a rock... and staying that way
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    You have probably got a split radiator side tank , these are plastic & best to replace with a new radiator , about $200 plus labour to fit, suggest you refill it when cooled down then take it drive carefully keep eye on warning light to nearest repair shop, not wise to drive it in this weather , could damage the engine /blow head gasket, etc etc .
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    u needa try find where the leaks coming from...
    like hoses..
    if its a hose u can just replace it
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Vy Berlina
    Sep 2010
    Wollongong
    Thanks guys, its going to be a long afternoon...
    Is there a specifit coolant I need to refill with?
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by FATASS View Post
    Is there a specific coolant I need to refill with?
    Yes for the V6 engine use Castrol "Anti-Freeze 350 Coolant Concentrate" which is the correct spec coolant and meets the Holden spec HN 2043. It's a concentrate to be diluted 50/50 mix with distilled/de-mineralised water (like Glendale distilled water). (Nulon also have a coolant concentrate product that meets Holden spec HN 2043 for the V6 engines. ) This coolant spec is covered in your owner's manual.
    Don't use a product that does not comply and it is unwise to mix different brands of coolants (according to the manufacturers of these products).
    When the leak problem is fixed flush the whole cooling system with water , fill with fresh coolant mix and ensure the system is well bled of air using the bleed screws. You should also purchase the coolant pellets from Holden and add these to the coolant when filling the system. You simply crush 3 of them into powder form in a plastic bag (with a hammer) and add it to the radiator fluid. (When filling the system don't forget to top up the overflow reservoir to the correct level. Preferably this reservoir should be removed and cleaned out). After flushing the system there will be some clear water remaining in the system so ensure you increase the coolant concentrate proportion to compensate for this. Otherwise the fluid mix will be too diluted.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    Don't forget the thrermostat i cold be faulty and you should replace it if you have overheated your car.
    VY V6 Wagon
    May 2009
    Tauranga NZ
    I'd just fill it with water until you get the leak / problem sorted out then use the correct mix
    Vy Berlina
    Sep 2010
    Wollongong
    Topped up with water and managed to get home - its definitely a crack in the radiator
    Will get a quote on a new radiator tomorrow
    Thanks for all the help lads!! This is why I love this forum
    Sep 2007
    Quote Originally Posted by maccasparks View Post
    Not a problem , seeing you have to pull the radiator out you might as well change the hoses too , also try & buy a Heavy Duty radiator , they have a 16mm wide core instead of the piddly 11 mm standard core , not that much dearer either.
    Vy Berlina
    Sep 2010
    Wollongong
    Any recommendations on where to buy & brands?
    Calsonic any good?
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    PWR, it will never break again if you use them!!
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    Vy Berlina
    Sep 2010
    Wollongong
    OK, so radiator is now replaced. But im noticing that the fan isn't coming on at all. (May have been why the radiator died in the first place)
    When I switch the A/C on, the big fan works. But the smaller fan closer to the battery wont come on at all.
    How can I diagnose where the problem is? I figure it could either be electrical or the fan motor is stuffed? Are they easy to replace?
    Cheers!!
    VY S Series 2
    May 2010
    the fans will only come once the engine reaches a certain temp. im pretty sure the bigger one kicks in first and then if the temp still keeps going up the smaller one kicks in too although. sit the car somewhere and leave it running keeping an eye on the temp gauge and see if it starts to overheat. if it does and the fan doesnt come on then you got problems
    Vy Berlina
    Sep 2010
    Wollongong
    Fans are definitely not coming on, just went for a drive and let if run for a white. Usually the fan would come on at the lights or when i pull up at home. Only way I can trigger it is to put the A/C on
  15. #15
    VY S Series 2
    May 2010
    but is it overheating without the fans running? if its sitting there and not getting any hotter then it doesnt see the need to turn the fans on and wont
  16. #16
    Vy Berlina
    Sep 2010
    Wollongong
    Quote Originally Posted by Dr HaxZaw View Post
    Nah hasn't moved above the normal temp yet. Maybe im just paranoid after the other day lol.
    Anyone have any tips on cleaning up the engine bay? The coolant has left a nasty white residue everywhere & it smells a bit when im driving.
  17. #17
    VY S Series 2
    May 2010
    degreaser and a saturday morning
  1. Overheating issue
    By ETH4N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2010, 04:49 PM
  2. VX Overheating Issue
    By King_berald in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-08-2010, 10:19 AM
  3. Coolant/Overheating issue
    By Maxo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2010, 02:03 PM
  4. Another VX Overheating Issue
    By phantom_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2010, 07:13 PM
  5. VX Calais strange overheating issue
    By marsh_e79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2009, 02:33 PM
