Results 1 to 14 of 14
Thread: Low beams not working all of a sudden - high and park fine
    Sep 2008
    Default Low beams not working all of a sudden - high and park fine
    Hello,
    hope you can help. The low beams on my VY commodore have just decided to simoultaneously not work.
    I have checked the fuses and relays (swapped with horn) and they are all fine. Park lights and high beam still work fine. The switch I believe is fine as I hear a clicking in the relays when the switch is turned to on.
    I fiddled with the wiring (which I assume must be the problem) and the left park light stopped working for a few minutes too. This leads me to believe its definately the wiring, however where on earth do I start to troubleshoot where the fault could be?
    Any suggestions or alternatives to what the problem could be?
    Thanks in advance.
    VY Executive S2
    Jan 2010
    open the screw plastic thing behind the bulb and play around with the bulb, mine sometimes loses contact cause its a bit loose so that could be a reason
    Sep 2008
    Thanks Daniel,
    have tried that too... Think there is a problem with the wiring between the relay and before it splits into left and right headlight...
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    what wattage are the globe yyou are using... sounds like your low beam circuit has been fried
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    Sep 2008
    Not 100% sure but they are the standard aftermarket replacements... have been using them for more than a year with no problems!
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    is there voltage from the fuse box to the light sockets?
    Sep 2008
    Thanks for your reply. Im not sure as I don't have a multimeter, however I would assume that there is no voltage running from the relay through the low beam circuit to the lights. There is only one connector socket per side which operates low beam, high beam and parking lights so there must be some volatge coming through as the parks and highs still work fine. Have unbolted the fuse box, but because the cables are so tight I can't move it more than a few inches, and thus its very difficult to actually trace the wiring from the low beam relay to the light sockets to see if there is any breaks in there... Can you suggest anything to solve this problem?
    Sep 2008
    Any more suggestions please? It is quite irritating as I can't drive at night now
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    have you tried changing the bulbs?, that would have been my first step.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VY S Series 2
    May 2010
    Sep 2008
    I changed the bulbs (even though i figured the chance of 2 bulbs blowing at excactly the same time was impossible) and they work again! I guess there must have been a short or a powersurge that blew them both at the same time...
    I also changed the park light bulbs, however they are not working now! I changed them with the lights on (only realized afterwards) so is there a chance I may have blown a fuse or something that would stop both from working?
    Thanks.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    check that the alternator is not overcharging. could be why both globes went.
    also, the parklight globes aren't LED are they? cause they only work one way around.
    Sep 2008
    Thats a good point, if it happens again I will get that checked. And no, they are standard bulbs... Though its a little weird they wont work.... Is there a fuse just for the park lights?
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    do i have to say it again change the parkers now an see if thats works , yes you may have blown both parkers. it worked last time.
  1. VZ low beams off when high beams on
    By BigBro in forum Electrical Wiring / Questions
    Last Post: 01-09-2009, 07:50 PM
  2. ve sv6, high beams? help
    By acca00 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-05-2009, 11:15 AM
  3. High Beams in a VT
    By MY.97.VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2009, 05:19 PM
  4. High Beams
    By SNY.3LT in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2005, 10:41 PM
  5. VR High Beams
    By AirStrike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 03:47 PM
