Results 1 to 7 of 7
Thread: Installing a car lighter in a VY S SERIES 2 (2004)
    holden commodore s series 2
    Feb 2011
    sydney
    Default Installing a car lighter in a VY S SERIES 2 (2004)
    Ive got a Holden S Series 2 2004 model, and the problem is they don't come with a car/cigarette lighter, as i need one.
    Has anyone had one manually installed? Just wondering a rough price to get it installed all together, and where you got it done etc.
    Thanks..
    VY Executive S2
    Jan 2010
    im pretty sure theres such thing as a smokers pack that sits where the 'storage bin' is, i'd assume the lighter would run off the power supply that runs through the centre console
    edit:
    just googled it take a look
    http://cars.ebay.com.au/NEW-HOLDEN-C...mZ300472499181
    vy executive
    Mar 2006
    Bacchus Marsh
    Hi I wanted another power outlet so i got and installed a smokers pack,its easy to install as the plug for it is already there,and i think i only paid about $50 of ebay
    Feb 2011
    sydney
    Thanks alot daniel...
    Steve, thats great to hear... so you installed it yourself? if thats so ill be cheering haha thought it was gonna bloody cost me big bucks
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    It's pretty easy to do. You need to remove the top of the console between the seats. This just unclips but it has one small self tapper located at an angle under the drop-down comparment lid at the front of the console. Lift the rubber mat out, and the screw is located at about 2 oclock as you look in. The top then will pull up - start at the rear and be firm but not rough. There are numerous clips and they can be a bit stiff but it will come up ok. Then remove the stereo unit using two bent pieces of coathanger inserted into the four holes and pushed sideways to the outside of the car. The stereo can be easy or stiff - it varies from car to car, but it will come out. You can then access the screws to remove the small bin with the closing lid. Under that, you will see a white connector plug clipped to the right hand console bracket. The ashtray and lighter assembly just replaces the lidded compartment, with the lighter plugging into the connector. Put everything back in reverse order and you should be sweet.
    vy executive
    Mar 2006
    Bacchus Marsh
    yep I installed it myself ,just as calaber said its very easy as long as you follow those steps
    Scruba's Avatar
    Scruba is offline VY II SS Driver
    Pontiac Firebird/VX 2 Acclaim/VY II SS
    May 2011
    Quick question on the smokers pack. I notice on ebay that there is also a facia. Does this clip onto the front of the lighter door?
    Black on Black is beautiful!
  1. [SA] Vy executive series 2 2004
    By WILDMAN VZ in forum Vehicles For Sale
    Last Post: 21-03-2010, 02:11 PM
  2. 2004 VY Series 2 SS
    By Uber_Matt in forum VY - VZ - WK - WL - V2
    Last Post: 05-10-2008, 07:53 PM
  3. 2004 VY Berlina Series 2
    By exec24 in forum VY - VZ - WK - WL - V2
    Last Post: 10-05-2007, 07:11 PM
