Results 1 to 9 of 9
Thread: Help, can't get into my car
    Mercedes C200K AMG-Sports
    Mar 2007
    Default Help, can't get into my car
    Oh oh. I can't get into my car.
    I have been recovering from an operation for about a month. I tried to open my car yesterday and I can't, battery is completely drained. I think the stereo didn't switch off properly because the radio antenna is up.
    I can't unlock it with the key remote or with the key!
    So I can't even open the bonnet to jump-start the battery.
    Any ideas how I can get in without causing damage? I also bet it's double locked.
    It's a wk caprice with only a lock on the driversside door.
    /posted via mobile device\
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Use the search tool.. It's been covered more than I can count with my fingers and toes :P Clicky. Good luck on yur recovery
    Cheers,
    Dave
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Turn key to the right with a fair bit of force, it will unlock.
    Silver Certified.
    Mar 2007
    Quote Originally Posted by RiCeY View Post
    Did work?
    Mar 2007
    Quote Originally Posted by caaf View Post
    I will try when I get to a pc. Using an iPhone forum app and it ain't letting me search.
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    I had this problem a short while ago. Turning the key hard clockwise didn't work for me (this does for most though). In the end I jacked the car up and hooked up a trickle charger to the starter motor. This put enough juice through the electrics to hit the button and pop the lock. (I turned the power on the charger then straight away popped the lock)
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    I think the problem is the barrel is never used due to remote central locking so it must seize up after a while....
    Silver Certified.
    Mar 2007
    Ok. I dared to turn the key clockwise enough to make me think it will snap and hey presto. Open
    I'll call the RAC to start the car Wednesday if my doctor says I'm ok to drive.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    This reminds me: we are supposed to lubricate the door lock with graphite powder from time to time. I never have, because I never use it. Lesson learned though, I might do it now in case this happens to me.
