Results 1 to 7 of 7
Thread: Mysterious water leak. (water drips from bonnet lever?!?)
    HBD VY Berlina
    Feb 2011
    Default Mysterious water leak. (water drips from bonnet lever?!?)
    Hey guys
    first post on the site but I've been reading for about a year, learning alot! researching and I ended up with a HBD VY Berlina with 60k on the clock in a sexy shanghai red!
    The car is great except for this damn leak which is driving me insane!
    The leak seems to be coming from the drivers footwell from under/behind the dash on the right side and dripping down the bonnet release lever, It happens when water is run over the drivers side pillar/door.
    I have cleaned out all the "plugs" on the drivers door, are there any plugs/drain holes under the bonnet or ones I may have missed?
    I had a look at the weather strip on the roof of the car, saw a gap figured i would seal it just incase that was the cause but it has not helped.
    Could a faulty door seal/weather strip cause the water to leak out from BEHIND AND UNDER the dash?
    Any ideas as to WHERE this water is coming in?
    HBD VY Berlina
    Feb 2011
    UPDATE:
    seems to be comming in from the bottom of the windscreen, I will be having it checked and windscreen resealed in the next few days will update if it solves the problem
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Yeah probably the windscreen. I haven't heard of a door leaking on a VT-VZ unless the cars been in a smash.
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    My VT leaked from the bottom of the drivers side windscreen from new. Took Holden til almost he end of waranty period to confirm, find and fix the problem.
    Get them to pressure test it. It leaks where the three body panels meet. Apparently sometimes not enough sealant went in.
    Fix was to remove windscreen, reseal body panel joins and refit windscreen.
    VZ Commodore SV6
    Mar 2011
    I have the same problem in my vz sv6. did getting the windscreen resealed work?? I'm not too keen on payng $200 if it doesnt work.
    VE SS Sportwagon
    Feb 2010
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Yep Same Thing Here, Turns out about Half of the side of the windscreen was not sealed at all, $120 to have it resealed. fixed it no dramas at all now :-)
  1. water leak! please help
    By bobby digzz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2010, 11:01 PM
  2. Water leak
    By coolvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2010, 12:14 AM
  3. water leak
    By chook69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2010, 06:16 PM
  4. Water Leak...
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2009, 02:57 PM
  5. water leak
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2008, 10:08 PM
