Results 1 to 2 of 2
Thread: VY Mechanical Noise?
    VY Series II V6 Sedan
    Jan 2011
    Australia
    Default VY Mechanical Noise?
    So this is going to be hard to explain, but when I drive my car at certain speeds, it makes a strange pulsating mechanical noise when I sit at certain speeds, usually 100Ks exactly, going slightly faster or slower, the sound goes away.
    Its very constant/rhythmic like "vrrr, vrrr, vrrr, vrrr". I'm not too sure if its coming from engine or g/box. Any help would be much appreciated!
    Current Ride: VY Series II 3.8L Sedan
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Is the gear box manual or auto?
    Are you sure the noise originates from the engine or gearbox and not elsewhere up front? (Last time I heard a noise as you describe (not in a commodore) it was present most of the time when you applied the throttle and sounded like an auto gearbox problem, especially when under load. But the owner claimed it was something else).
    As you say the noise starts in your car at about 100 kms are you sure it is not front wheel/hub/bearing related? Just a thought.
  1. VT Mechanical Problems - Help
    By Dodson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2010, 11:03 AM
  2. Any mechanical problems etc on VZ??
    By Shelz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-10-2009, 03:00 PM
  3. vn mechanical manual
    By grothie1978 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2008, 05:24 PM
  4. SV6 Mechanical Issues
    By Nordy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-09-2007, 03:45 PM
  5. need mechanical help
    By andyman in forum General
    Last Post: 29-06-2006, 09:32 PM
