Results 1 to 10 of 10
Thread: check engine light is on!whats wrong?
    VY03A
    Feb 2011
    sydney
    Unhappy check engine light is on!whats wrong?
    i just borght a 2004 holden VY03A 2 weeks ago. 100km. and i did a big service. everything is fine but got one problem! when i driving everything is fine...drive like new....but stop without turning off the engine like 10mins. the check engine light is on! anyone noe whats wrong with my car!?
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    It could be any number of things.. Mind I do sit around an under voltage issue maybe... What testing have you done already.. What's the error codes are you getting?
    Cheers,
    Dave
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    my guess is it is an Oxygen Sensor problem. There are 2 of them in exhaust manifold on a v6 engine , about
    $80 each , easy to change .
    02 VY SS
    Apr 2010
    could be anything o2 sensor throttle sensor oil pressure sensor to many bloody sensors
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Try tightening your battery terminals.
    Visit my Facebook page
    VZ Ute
    Jan 2010
    Wollongong
    mines the same now. i pulled off my whole air intake from throttlebody to box then when i reassembled the engine light came on. what could be the cause? 02 sensor? throttle sensor? help me too haha.
    sorry officer..thought you wanted to race.
    Sep 2007
    you may have an ambient air leak into the inlet manifold somewhere after the MAF sensor , check your rubber tubes to the heater actuators at the rear of the inlet manifold & the brake booster vacuum hose . make sure the inlet ducting is airtight to the throttle body. Still reckon its the Oxy sensors though......
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did you plug the air temp sensor back in?
    VZ Ute
    Jan 2010
    Wollongong
    yeah i did lol. possibly a leak somewhere, may not be air tight. but im guessing ive definitely buggered a sensor along the intake somewhere.
    VY SS 2002
    Feb 2011
    Pakenham Vic
    Our check engine light started coming on then the motor blew up (injector was staying open and sump had a hole in it)
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Check Engine Light
    By sheapard in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-12-2010, 10:52 PM
  3. Whats wrong with my 94 VR Commy? Engine issue?
    By EvilMonster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2010, 07:27 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. check engine light!
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 09:02 AM
