Im having an intermittent starting problem,
one day suddenly when i went to start the car it wouldnt turn over tried a couple times, nothing, took the key out tried again and she fired up no problem. (this was about a week ago)
no problems since until today went to start the car but it was not turning over so i keep cranking i get CHECK ALTERNATOR warning
Like ive said this is an intermittent problem that comes and goes as it pleases
I have check the voltage of the battery via the VY computer ad it has said 13.3 idling, 13.8 if i rev and 12v without the motor running
What do you guys think is the issue?
worn brushes?
Starter solenoid crapping out?
Im hopefully going to be able to drive it to my auto elec to have a look see tommorrow, I cranked it over a few times while checking the voltage via computer and it kicked in without a problem so im hoping that means the alternator is fine and its either the regulator or the starter solenoid
any input appreciated
Hi this may work it may not give the probe thing on the key a clean and give the metal channel where it connects to on the ignition barrel when you put the key in a clean as well,maybe its not making contact properly......
cheers steve
i have a VY S II and i have the same problem!! it comes and goes like you said. i never new about the key contact thing though, will give that a try. thanks
