Results 1 to 10 of 10
Thread: MAF Filter?
    S/C VX Calais
    Apr 2010
    canberra
    Default MAF Filter?
    im going to install a new CAI and wider piping and was wonderng if i should i take out the honeycomb mesh in the MAF? would it stuff up my car at all?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    It will stuff around with the car if you remove the honeycomb in the MAF. It is there to ensure an even, regulated flow over the sensor.
    Ronald Reagan (1986)
    S/C VX Calais
    Apr 2010
    canberra
    VY S Series 2
    May 2010
    the MAF tells the engine how much air its getting (im pretty sure correct me if im wrong)... so if the computer thinks its getting more or less air than it really is then the amount of feul being injected will be wrong so it would be in a bad way... depending on how good you were are taking the honeycomb out it might not matter too much but i wouldnt bother really
    VT
    Apr 2005
    QLD
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    i took the mesh out of mine an it drove fine for 3 years till i got a mafless tune. but most people on here will tell you not to take it out for the reason acarmody has stated.It is a restriction.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VX Berlina
    Apr 2007
    Let me put it like this. The ECU uses the MAF to determine how much fuel to add, because it know how much air is flowing in. Now it can do this because the MAF is giving it a nice reliable reading since the air is smoothly passing over the MAF sensors (those little resisters). Now if you remove the honeycomb, it can allow turbulent air to flow over the sensors, so it can get an unreliable reading.
    Like the guy above posted, it may run alright, or it may not. Its totally up to you to decide if you want too.
    If you want a gain you can install an LS1 MAF which are bigger but than you will need a tune to suit.
    VT
    Apr 2005
    QLD
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Beg to differ , but removing the screen ( the restriction) allows a greater volume of air to be sucked past the measuring resistor grid , remember the greater volume of air you can cram into a cylinder coupled with matching fuel ratio, will give a greater explosion thus driving the piston down , thus giving more power!!!!
    Ever tried to blow thru a flyscreen ??? Its a lot harder than without it. The MAF measures Air Flow in Cubic Feet/minute , (or the metric equivalent) . The aim of the game is to get more cu/ft min past the sensor so it signals the ECU to program more fuel to match.
    VY S Series 2
    May 2010
    Nobodies arguing that point... what we're trying to say is that the engine needs to know how much air is going in and it needs to be pretty accurate... if the car thinks its getting more air than it really is then its going to be running rich and vice versa it would run lean... if you understand the whole concept of air flow youll understand that the sensors need "stable" air (laminar flow) otherwise its starts measuring eddies and vacuums which [B]could[B] lead to your engine running weird. IF you can get a MAF made without it you would be better of doing that as its been designed that way not chopped up and smoothed out
  1. POD filter on a VX
    By Astro112 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2009, 05:47 AM
  2. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  3. VE SS Air Filter ?
    By BOY1236 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-07-2009, 06:31 PM
  4. pollen filter/air con filter
    By binghy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-05-2009, 11:45 PM
  5. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
Tags for this Thread
