Results 1 to 5 of 5
Thread: Aerial Problem
    VY Crewman
    Feb 2011
    Parkdale Vic.
    Default Aerial Problem
    I replaced the standard single stacker Blauplunkt cd player in my VY Crewman with a 6 stacker Blauplunkt unit. All good, fits exactly like the instructions said it would, except that the auto aerial that used to rise and fall with ignition on/off doesn't. Neither does the Up/Down aerial control on the 6 stacker work. Can anyone tell me how to fix, or even how to access the aerial unit.
    Hot House VY SS
    Jan 2010
    You have to get Holden to program the new unit into the car with the tech 2, once this is done the aerial will go up and down as normal. Holden should only charge 1/2 hour labour to do it
    VY Crewman
    Feb 2011
    Parkdale Vic.
    VY S2 Equipe
    Dec 2010
    Adeladie
    I have something similar.
    I got my stacker taken out and replaced with a pioneer one
    Problem is my aerial will always go up when you turn the stereo on, even if im using a CD and not the radio it will always go up
    Is this an easy fix?
    -The Pommy With A Commy-
    I Don't Care What You Say, But My Commy Is The Fastest Car In The World
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by -VY LoVeR- View Post
    In your case it may be that the stereo remote wire (ie used to turn amp on) is connected to the aerial instead of the aerial control wire. A simple fix once you get the stereo out and look at the wires.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
  1. electric aerial problem
    By ss905l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2010, 09:49 AM
  2. Replacement Aerial Mast Problem
    By alien in forum Car Audio
    Last Post: 19-12-2009, 03:55 PM
  3. Stereo / Aerial problem on VY S
    By stimwe in forum Car Audio
    Last Post: 15-12-2009, 07:33 PM
  4. Pioneer CD tuner and electric aerial problem
    By VR mad in forum Car Audio
    Last Post: 20-05-2008, 11:02 PM
  5. Panasonic Head deck wiring /aerial problem
    By markc3012 in forum Car Audio
    Last Post: 05-02-2007, 11:16 AM
