Results 1 to 11 of 11
Thread: Solving that annoying vibration or rattle at idle
    VY S V6 Ute Series II 2004
    Nov 2009
    Default Solving that annoying vibration or rattle at idle
    I’ve noticed a lot of posts by VY V6 owners (mostly series II) trying to solve without much success a vibration or rattle that haunts them while sitting at the lights in drive at idle, but goes away when they drive off or increase the RPM slightly.
    There are a few obvious things that you can check and fix like
    (1) Loose or bent heat shields. The insulation material inside them breaks down or comes loose too sometimes.
    (2) Not enough clearance between the exhaust and chassis or busted rubber exhaust hangers. Loose pipe connections. Tighten the flange where pipes connect to manifold.
    (3) Bits of loose material inside the system
    But if you’ve done all these checks and it still rattles or vibrates then check the flexible exhaust joint with the two springs on it. Make sure it is aligned so the sides of the bolts don’t touch the flange they go through, or touch the coils of the springs. Make sure there’s plenty of clearance.
    If it is misaligned even slightly you’ll get a vibration. It took me ages to track down this last remedy and it made the car a pleasure to drive again!
    I thought I’d share it. Hope this helps someone else out there.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Wicked dude, ill have to check this out
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Some good tips there mate
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Nov 2009
    Yes new engine mounts can make the VY a much smoother car. They seem to only last about five or six years before they sag a bit and you start to feel general harshness or vibrations through the steering wheel.
    Don’t know why they give up the ghost so early in the piece…most other types of car’s engine mounts seem to last the life of the vehicle.
    A mate recently fitted new mounts to his and when he asked the guy at Repco if they had any in stock he said “75 out the back…plenty mate”
    What’s that tell you?
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Hey Guys im just tossing this in here with my VY Rattle.
    Only does it at idle and seems worse in reverse.
    I found if i push the gear selector to the drivers side, the rattle goes away, if i push it to the left it seems likes its rattling against bare steel. Im still yet to look and find out what exactly it is. see if any of yours are the same at all.
    Nov 2009
    You got a manual or auto transmission?
    If you’ve got an auto the shift shouldn’t move from side to side at all.
    Either type of transmission it sounds like the problem could be worn bushes on the linkages letting them rattle around.
    Or the floor console might not be clearing the shifter enough and needs adjustment.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    have to apply quite alot of pressure to it, Feels like the shift stick is touching some metal and then vibrating through the car, As said might be the floor console or something else, i need to remove the console and have a look down it. the transmission is so so smooth :-) Never had one this smooth so i know its fine.
    VY 3.8ltr ute
    Jun 2010
    Nov 2009
    This is the type of exhaust joint we're talking about to look for that rattles or vibrates.
    Attached Thumbnails Attached Thumbnails Solving that annoying vibration or rattle at idle-exhaust-ball-join-coupler.jpg
  1. Annoying Rattle/Vibration/Ticking in Idle
    By lkorruptl in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-05-2010, 01:52 AM
  2. Annoying Rattle....
    By SHANBANGER in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2009, 05:26 PM
  3. Annoying vibration noise.
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2009, 01:21 PM
  4. Annoying Exhaust Rattle
    By 89berlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2008, 11:57 AM
  5. Annoying Rattle in Vk
    By gone_nutz13 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-05-2005, 02:59 PM
