Results 1 to 22 of 22
Thread: VY dash clusters
    02 VY
    Jan 2011
    Default VY dash clusters
    Hey guys. Got a standard vy exec but the dash cluster is boring. Am I able to change it to an ss cluster or any other models? Mines a series 1 do I have to stick to series 1 clusters if I can get an ss? What's involved in changing them over? Any help would be appreciated as I don't know much about this. Cheers.
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I believe that you can simply change over to a higher class one but pretty sure you have to stay to the same series as if you swap, the fuel gauge will read backwards or something like that.
    A Commodore is a passion. Anything else is just a car
    VY executive
    Oct 2008
    Quote Originally Posted by DUK13Y View Post
    Correct, Im sure you can put in any other cluster as long as it is Series 1. The kilometres reading on the cluster will also need to be matched with the car which will require a Tech 2 Diagnostic tool.
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    You can use any series cluster, im running a series 2 VY Berlina cluster in my Series 1 Lumina... all it needs is Tech -2 and done
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    vy executive s2
    Jul 2008
    Quote Originally Posted by D3CID3R View Post
    You can use any series cluster, im running a series 2 VY Calais cluster in my Series 1 Lumina... all it needs is Tech -2 and done
    correct but if you are getting Phreddy to do a dash conversion for you he will not be able to do this as his tech 2 does not allow him to do this. (just incase you were thinking of getting him to do it along with other work)
    CAM'S VY PHREDDIFIED AND LEATHERED!
    http://forums.justcommodores.com.au/...w-leather.html
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Don't know where u got that from because phreddy did my dash conversion
    vy executive s2
    Jul 2008
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    sorry double post
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    could have sworn its a series 2.. will double check some images..
    vy executive s2
    Jul 2008
    Ok maybe I could be wrong but I'm sure he said he couldn't cause his wasnt genuine tech 2 but could do everything else
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    heres my dash
    and heres an example off car sales.. its a s2 berlina daah
    http://www.carsales.com.au/Tig/UI/Pa...3&tabID=304744
    vt acclaim gen 3
    Jul 2009
    vic
    yes they do have to be the same series because i have a series 2 cluster in my series 1 and the fuel guage reads backwards. Can anyone confirm that simply changing the fuel guage sender to a series 2 will rectify this problem?
    henrytad
    hey everyone, ive always liked the noise of a blow off valve hissing at the change of gear, n was wondering if there is a way to hook one up on a alloytec 3.6L without a turbo?
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    ??? mine works perfect...
    White S2 LX Captiva Diesel
    Oct 2005
    When I was looking at HSV clusters for my VYSS I was told that since my car is a series 2 I had to get a series 2 cluster the series 1 cluster would not work.
    The VY and VYII have different fuel sender units and the software that controls the fuel data and the sender units is different(i think uts made by 2 different companies). If you fit the wrong series cluster, then the fuel guage will work back to front which makes the the DTE (distance to empty) on the trip computer unusable. You can fix this by changing the fuel sender unit to the compatiable type I've heard it costs a few hundre bucks to do though.
  15. #15
    vy executive s2
    Jul 2008
    Go to Holden get them to use there tech 2 to rectify it for you should cost like $50 alot cheaper
  16. #16
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    A tech 2 is unable to change the odometer unless it has less then 100km on it (thats 100km, not 100,000km). Some people have worked out how to change it with more then 100km though, Phreddy from ASR-Audio can do this.
    The tech 2 is able to set up everything else on the cluster - V6/V8, Auto/Manual, number of airbags, diff ratio.
    Quote Originally Posted by sly_gen3 View Post
    Yep, series 2 sender will fix the problem.
  17. #17
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Can someone explain why my dash works then?
  18. #18
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Berlina S2 and Calais S1 are identical in apparance. Berlina S1 has a slightly different font then Berlina S2. Calais S2 has a different font again, black background and monaro style needles.
    If your dial background is grey, then you have a Calais S1 cluster. If it's black you have some kind of hybrid job made of parts from all different clusters Probably VY2 Calais or VZ Background put into a VY1 cluster.
  19. #19
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    It must be an s1 calais cluster then...
  20. #20
    S/C VX Calais
    Apr 2010
    canberra
    so basicsally what your all saying is that if i have a vy series 2 i go get any model dash, even level 3 dash? aslong as its series 2?
  21. #21
    02 VY
    Jan 2011
    Thanks for the help. What's it like to remove and put the new one in? Just looking at a few on ebay, might also check out some wreckers.
    So the kilometers can't be changed even with a tech 2 tool? I have a mate who owns a panel shop who knows how to do it. The cluster I'm looking at has 230k on it compared to 150 on my car. Just wanna know everything before i commit to the buy. cheers.
  22. #22
    vt acclaim gen 3
    Jul 2009
    vic
    Quote Originally Posted by TMM View Post
    thank you!
    henrytad
  1. VR/VS Dash Clusters
    By SLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2009, 06:01 PM
  2. vk dash clusters
    By NOT.BT1 in forum Parts And Other Items For Sale
    Last Post: 22-10-2007, 05:56 PM
  3. Vn Dash Clusters
    By statesman_wagon89 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 01:12 PM
  4. dash clusters...
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2006, 12:56 PM
  5. Dash Clusters
    By tommythe1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2005, 12:36 PM
