Results 1 to 16 of 16
Thread: ECOTEC cutting out
    VY S Series 2
    May 2010
    Default ECOTEC cutting out
    ok so i got a new exhaust installed last week and then yesterday morning i banged it on the gutter getting out of the drive (yes the driveway is weird)...
    now its cutting out randomly changing down through 5th,4th and 3rd... battery and alternator are fine and we've upped the base idle and thats only made the engine run like a dog so i gotta change it back.
    when i change (and make a slow change) down the engine drops till about 400rpm and either picks back up to about 800-1000rpm or it stalls. it sounds like sometimes i have a leak in the exhaust and its sucking air in when i back off and then sometimes it doesnt and i cant figure it out. is it possible for a leak in the exhaust to be causing this problem?? the leak seems to be from around the gearbox area.
    any ideas are appreciatted no matter how retarded cause its annoying and scary having your steering go while your slowing down for a roundabout
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    is the cat damaged?
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VY S Series 2
    May 2010
    is the cat damaged
    i thought it sounded like it but nobody else reckons... you can hear the air running through it real easily when you listen under the car
    blown vy v8 ute
    Jul 2009
    Quote Originally Posted by Dr HaxZaw View Post
    Hey mate sounds like you may of smashed your oxy sensor .. Get under and check they are both there and intack if so check the rest of the exhaust for breakage Ect I hit a too and smashed the oxy sensor off my ute was missing and being a pig till I got replacements
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    mate jack your car up and see exactly what you have hit.. then you will know what to fix and see if it eliminates the problem which it will if the problem occured after you hit your exhaust....
    VY S Series 2
    May 2010
    so it just developed the mother of all misfires but thats fixed now with new leads and spark plugs... checked underneath the car and all i did was hit the flanges between the extractors and the cats... no leaks and the oxy sensors are all good so i still have no idea
    still stalls on the odd occasion when downshifting between 5 and 4 and i have no idea why its doing it. revs just drop to 400 and it either stalls or picks up again... if i shift quick enough it wont do it but if i leave the clutch in for about 5 seconds it will
    VY S Sedan
    Sep 2007
    Have you checked the vacuum hose at the bottom of the throttle body?They can fall off and cause a lean mixture.
    VY S Series 2
    May 2010
    just checked the vacuum hose and throttlebody... seems fine no leaks while running or anything
    weird thing is that it idles normal when shifting down in 1st and 2nd and then the revs get progessively lower the higher the gear is
    im wondering whether one of the exhaust sensors is damaged but they all look fine and even if they were how could they cause this problem cause its not consistent that it would be alright in lower gears but not high gears
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Um what?
    Thats what taller gear ratio's do.
    VY S Series 2
    May 2010
    Um what?
    what i mean is that if i change down to 2nd or 1st the revs dont drop down to 400 if i leave the clutch in long enough. the engine just drops to about 800-900rpm where it would normally drop to for all the gears whereas if i do it in third it drops to about 500-600rpm and 4th and 5th drop to 400rpm and itll either jump back up again to 800-900rpm or itll stall... it wont stall if i change gears quick enough so that the engine doesnt have a chance to drop the revs but id rather solve the problem rather than ignore it
    VY S Series 2
    May 2010
    does anyone know if there is a sensor in/on the gearbox that might be telling the engine that its still in gear and so the engine isnt injecting any feul until it thinks its about to stall??
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    VY S Series 2
    May 2010
    VY S Series 2
    May 2010
    ok so this just occured to me. when it started stalling the first time it was just after i put a tank of 95 in it (i usually run v-power). now that ive got v-power back in it its not stalling but the revs are still dropping real low. any ideas????
    would tech 2 or whatever it is help with this or not?
  15. #15
    SBM
    SBM is offline
    VS 5Spd
    Aug 2010
    Streaky Bay
    I'd give your throttle body and IAC motor a good clean sounds like its not idling properly.
  16. #16
    VY S Series 2
    May 2010
    ill give it a clean but it idles nicely so im thinking along the lines of a sensor error or something like that
  1. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  2. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  3. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  4. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
  5. Cutting out
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2006, 05:25 PM
