Results 1 to 9 of 9
Thread: vx 2 vy
    vy s2 exec 6cyl@vt calais 5.0
    Mar 2011
    bendigo
    Default vx 2 vy
    hi can i put a vx v6 engine staight in my vy [do i have to change computer etc]
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I don't see why you can't. They're both the same engine so should in theory run the same computer and settings. Don't quote me but there can't be much difference mechanically between the VX and the VY.
    A Commodore is a passion. Anything else is just a car
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    I thought if you put an older engine into a newer car vicroads or whatever higher power ####s on you and refuses rego?
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    VY S Series 2
    May 2010
    yup you cant put an older engine in a newer car... also the vy has a bigger sump so i dunno if that makes any difference
    Mar 2011
    bendigo
    i'll check it out wid em but i wouldnt of thought it wuld be a hassle iff theres no structurel changes ,
    i looked at the wreckes websites n their sellin vs vt vx vy motors to suit it i no there out for a dollar but ya thnk there wuld be a few ####ed off people if that was the case {sure theres not like a 5 year time frame or sum kinda loop hole}cheerzzzzzzzz
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    yeah ive heard that theres some law about emissions and some other mods they have done between the VT and VY's .. as far as im awake the VX and VY are exact same motor, but a motor before VX's you might have some trouble with..
    And as HaxZaw said the VY's have a larger sump,
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by a1k3m1 View Post
    This is how i understand it aswell. As long as any difference in the emissions gear (ECU, dual cats on 2004 models) is carried over to the replacement engine i can't see an issue.
    Mar 2011
    bendigo
    yeah sweet i got onto vicroads {after an hour} and they told me i could as long as it was optional im guessing that means bolts up the same !!
