Can somebody tell me is there a product on the market that will remove the squilling noise of brakes without removing the calipers and pads. But if pads have to be removed what is the best way to stop the noise. Disc rotors are fine and so are the pads.
Thanks
There is a product in a red bottle, I can't remember what it's called, Brake Stop Squeak maybe? It is a silicone, you put it on the backing plates of the pads and wait for it to cure, the refit the pads.
You could try bedding them in again, this can stop it sometimes.
Get up to 60km/h, brake HARD down to 10km/h without locking up, then get up to 60 again, repeat 4 or 5 times, you will start to smell the brakes, once you can smell them, they are bedded in.
