Results 1 to 12 of 12
Thread: VY fuel filter... HELP!!!
    VZ SV6
    Apr 2010
    Default VY fuel filter... HELP!!!
    Hey guys,
    I read up on a few 'how to' guides on changing the fuel filer on the vy didn't have any problem getting the filter off, however when I replaced it with the new one the 'in' end is leaking a significant amount of fuel! I tried multiple things to get it on right but it goes as far as a 'click' then no further...any thoughts???
    I made sure there was no damage to the links and made sure that it's the same ryco filter with the same product code.
    Please help!
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    I think there is a small Rubber o-ring inside the Quick Release Connector that stops leaking. This could be damaged or misaligned. Not sure if it can be replaced. But worth checking.
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    how did ya get the damn thing off dude!!!!! haha.. i cant even get it off in the first place!
    VY II SS Ute m6, VS Calais
    Jan 2010
    Perth, WA
    took me a while to get mine off but if you squeeze the clips hard enough it comes off bud. just do it on an average day rather than a 40 degree one.
    @ OP try some thread tape (htpe tape) around the outside of the filter, if that doesnt work you might be up for a new fitler or hose clip
    VZ SV6
    Apr 2010
    Well I tried for about 1 hour on my VZ and gave up! The filter 'out' end is very different to the VY... On the VY I just followed the instructions on some of the other posts... Push in and press the button that release the clip and pull back. Note: i found that twisting the filter a few times dropped some dirt that would have possibly made the job much harder...
    Lucky the side thats leaking is the tank to filter hose, should be much cheaper to replace than the one running to the bay.
    Any other thoughts? I'm spewing coz it's such a simple task that shouldn't require much effort at all!!! The vl was so easy, why did I ever get rid of it :@
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Make sure you have de-pressured the Fuel system, Makes it much easier i found. Also what i have known a lot of people cut the stupid quick release connector then just use clamps lol
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Yep my suggestion as well.. Pull out the fuel pump fuse run engine till it stalls and it all comes apart allot easier! I love the quick release as then the hardest job is un-clipping the fuel filter (which its not)
    Cheers,
    Dave
    Jan 2010
    Perth, WA
    if you wanna dodgy it up you can cut it and use hose clamps like the vs' do (that being said just keep fiddlin with it, it'll come off eventually)
    VY II V6
    Dec 2006
    This is for the VY owners. With one hand firmly on the filter and the other hand on the clip, push with a little force the connectors towards the filter. You don't need any fancy tools and be careful with the little tabs in the clips as you may damage them. Then all you need to do is slowly wiggle each end free. That should get the old one out. Just remember to look at the flow mark on the old filter before you remove it.
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    its a simple job.. maybe you didnt fully clip the clips back in properly
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VY SS S2
    Mar 2009
    Taree
    had the problem of destroying the T piece clip while removing filter. created new setup with brass 3/8 T and some fuel hose and clamps. main pain in the ass was when you cut the plastic clip off found that inside the rubber hose is a reasonably hard plastic fuel line so had to heat up with heat gun and cut the ends off old filter to use as joints, bit dodgy but it worked
  1. Fuel Filter and Fuel Line
    By King_berald in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:51 PM
  2. [ACT] VL Fuel Filter
    By sweefu in forum Parts And Other Items For Sale
    Last Post: 14-12-2009, 11:44 AM
  3. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  4. Fuel Line removal tools for Fuel Filter
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 09:56 PM
  5. Fuel Filter
    By plazma in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-02-2009, 08:14 PM
