Results 1 to 16 of 16
Thread: HSV VT CLUBSPORT help i bought a LEMON
    cruizin is offline CRUIZIN
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Wink HSV VT CLUBSPORT help i bought a LEMON
    hi peoples .. thought id come in here and pic a few brains cause in here id say their are some compared to the mechanics that ive had my car to lately..
    firslty i bought a VT hsv clubsport r8 from Motor Sport in Kenwick ( guys whatever ya do DONT GO THEIR FOR A CAR ) THEY ARE DODGY ..
    Now, my problem has been that since i bought the car when you go to open the car via the remote or lock the car via the remote only the left hand side lights flash if you open the boot with the remote also then all lights flash but no alarm on this at all any ideas? now im asking this incase it might be something that could be causeing my other issue.
    since i bought this car ive so far in 12months replaced the diff. cvs rear. front seal, radiator, althernator, condensor x2 compessor, starter motor, all pulleys. all belts. tx valve. air condition hoses and pipes, sunroof had fully serviced.exhaust. map sesor, oxygen sensors x2. relays. fuses.
    now these repairs have cost me in excess of 13000 dollars and i still have the engine light coming on. have checked codes or so the mechanic says..
    i picked my car up friday at a cost of another $900 the car went in due to lack of power chugging and rough run. th eengine light kept coming on..
    when i drove home the light didnt coming on any more until today then up she came again and again the car became sluggish.
    Anyone have any ideas here , my car has been to 4 mechanics including holden i have also replaced the body control sensor still nothing... please if you have any ideas would love to hear it ..
    clubbylicious@live.com.au
    D22 St-r Navara
    Dec 2010
    perth
    lol you went to motor sport, you silly silly man. biggest bunch of rip off idiots. mate bought a ba xr8 nothing but problems . paid 21k a few years ago, spent bulk money respray took it back in 4 months later cos he needed the cash they would only offer 14k for it. one of the salesman would take a used car home and do curb rashing fun in them.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    13k is a hell of a lot of money just for repairs, you could ask Holden to clear all the error codes then drive around a week or 2 and go back again and see what new ones it logs. I read that they have a memory of past errors even if they are fixed unless its cleared. (dont quote me on that though)
    From the sounds of things the engine light is probably caused by a faulty sensor but the mechanics should be able to scan that and tell what one it is, it thinks something is wrong and I assume the sluggish feeling is probably the car going in to limp home mode.
    At worst, if its not just a sensor fault it might be something internal if the sensors are all working fine.
    Lots of people here have had the same problem and its been covered many times if you try to do a search, I haven't had any problems with mine so I didn't pay much attention to the most common causes but it shouldn't be too hard to find.
    Best RPG ever
    carless for now
    Feb 2007
    perth,Western Australia
    VY S Series 2
    May 2010
    spark plugs and leads?? mainly cause you havent mentioned them but they can make a difference
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Quote Originally Posted by Krisp View Post
    hey krisp i hear ya their. they are the worst and selling high performance cars that they say they service pffft to them
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Quote Originally Posted by Vt_vic View Post
    go to pro auto mate they know ls1's back to front
    hey thanks for that were are they situated im in western australia im guessing their over in victoria mabye..
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Quote Originally Posted by Dr HaxZaw View Post
    thanks for your reply ,, i have done the leads but my usual mechanic that i dont have too many problems with had a look at the plugs last service and said they look fine.
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Quote Originally Posted by 2DIE View Post
    hi thanks for your coment
    i have replaced the oxygen sensors and map sensor plus relays and fuses. also on the paperwork the mechanic gave me he has listed .. motor running rough ecm light coming on all the time check for codes then he has eng/trans P0108. P0121,PO133,PO134,P0135,PO153,PO154,PP0155,PO327,
    PO523,P1133,P1153 THEN SAYS body control module 17 instrument s 08 says replaced map sensor and oil pressure sensor recheck for codes found one code PO154 02 sensor bank 2 out of range so their ya have it and that makes no sense to me being female lol
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Quote Originally Posted by cruizin View Post
    Also to add here , after tightening up the loose battery terminals thats when we got the error engine light when the car was cruizin the next day. and it slowed down as you said probably went into lymp mode.. had to keep giving it a bit of a boot to get it to move along ..
    today i went up to perth again from mandurah were i live and it seemed to run fine no lights came on im sure its got a mind of its own lol
    anyways back to the shop this week see if their is any codes come up
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    hey mate i have one also,had the same mechanical problem that you are having now,and it was my oil pressure switch.
    if its not that i'm not sure, i have also had previous problems with my abs module your abs light doesn't come on every now and then?
    My VL Walkinshaw replica project
    91 vn s
    Jun 2009
    Adelaide, SA
    For the ecu problems then maybe replace the ECU or swap it for a mates just temporarily to be sure there isnt a fault in the hardware. it's one thing you could cross off your list
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    Quote Originally Posted by somefool View Post
    you cant just swap the ecu,its gotta be linked to the bcm & keyhead otherwise no start as well as may cause other dramas.
    if you gunna check the ecu by swapping it you have to change all these bits as well.
    nothing worse than buying a lemon,things always turn sour
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    carless for now
    Feb 2007
    canning vale 10 mins form perth motor sport
  15. #15
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Default re my clubsport vt r8
    hi guys again its been a while since i posted basically ive had the car in and out of mechanics and also auto electricians. sheesh
    My son recomended after having a look under my dash that i take my car into someone and get them to rip out all the excess wiring that was in the car i must admit that after picking the car up and getting a box yes a box of wiring including tracking systems extra imobilizers and wires the car does actaully have more speed, but still not up to scratch.
    each time i have taken it to the mechanic they have fixed what the codes are then removed old codes and after a couple of days another code comes up and so it goes.
    ive had the oil pressure switch done and the map sensors and oxygen sensors relays have been done body control module has been done. we tried putting in another ecm that brought up traction control and abs problem which is different to what i had before.
    once again they fixed up a few more problems and i picked up the car only to have the light come on again this time now it comes up with trans sensor something or other input and also low oxygen level on bank 2.
    which if had replaced.at one stage there my lights would flicker all the time but now thats stopped, yesterday the indicator stalk started ticking like the flasher unit was playing up or a globe was blown but the flickers still work when i put them on but when it goes back to the middle it does the fast tick but without being engaged have to hold the lever to stop it. but today it didnt do it again sheeesh
    my son recons put some blue tak on the dash were the light is hahaahah funny boy ..
    also the mechanic told me this the other day can someone tell me if this is right as never heard of it.
    he said to me. " you have put extractors recently on your car yes"
    agreed i said
    so he asked me if the guy that had fitted them had put the right gasket goo stuff on?????? as he said if youdont put the right one on it will effect your sensor????? anyone can answer that one plz
  16. #16
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    havent seen your car around the 'drah mate, i live here too.
    shame about the problems, what a dodgy car yard
    If it isnt tuckin, it must be suckin
  1. Vy ss a lemon??
    By carlz04 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2011, 11:14 PM
  2. Grr bought a lemon!
    By vktorana in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2010, 11:42 PM
  3. Lemon?
    By mat123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2009, 01:23 PM
  4. have i bought a lemon?
    By BURK_POP in forum General
    Last Post: 11-03-2007, 01:56 PM
  5. vx ss..a lemon ???
    By doggie458 in forum LSx Development and Modification
    Last Post: 27-01-2007, 01:41 AM
