hi all does any 1 know how the fuel retun hose comes off that runs from the fuel rail and go's to the steel pipe that runs bak to tank ,i pulled it bak a bit and theres like an inner hose or sumfen can sum1 help please .
you need a fuel line disconnect tool, or i think you can make one out of a pen lid somehow
tool looks like this
They are called "quick connector" release tools.
ok cool n how do they work [wat do they atacth to] ?
they go around the metal pipe and you pull it towards the connector, then you twist and pull the flexible bit and it should come off
alright cool tnx m8 i'll giv it a crack!
too easy i just dot the end off a silicon cut it about half way then dwn the middle put it ova the hose and with a bit a force off it cum too easy cheers!!
whoops got a bit excited , i got the end {nozzle} off a tube of silicone ,cut it about half way than put a slit up the middle of it so it would go over the fuel line than apply pressure pulling it towards the front of the car while also pulling the hose and bobs ya uncle {good for wen ya cant get to supercheap to get the right tool or just wanna be creative![]()
