Results 1 to 6 of 6
Thread: VY electrical fault draining battery help please!!
    J.T
    J.T is offline
    2003 VY
    Dec 2008
    Alice Springs
    Default VY electrical fault draining battery help please!!
    I have a 2004 VY and was recieving warning that fault with alternator and battery light was coming up. Have tested alternator and it is working, (well was charging when read it) charged up battery and after a day it went flat. Thought it was battery so changed battery but now ABS warning comes up and all instrument guages are intermitent. they work one moment then drop to zero the next. The brakes work fine throughout the whole process though. fault only started a few days ago. could someone please give me some pointers as to what to look for? Thankyou.
    iaydemir's Avatar
    iaydemir is offline Donating Member
    VY V6 Berlina
    May 2009
    Had the same issues, the alternator light was intermittently coming on, along with the abs, airbag lights etc and the car went into limp mode a couple of times.
    The cause of mine were due to the alternator brushes being worn hence the alternator charging intermittently. It's worth giving it a quick check, its not hard and the brushes are cheap to replace.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    You do not mention how many kms your car has covered and if it is still running the original alternator but I assume it is the original.
    If your alternator was charging correctly then the alternator warning should not have displayed. You have eliminated any battery issue by installing a new one.
    From what you have described in your post, I would replace the alternator.
    J.T
    J.T is offline
    2003 VY
    Dec 2008
    Alice Springs
    Car has done 120,000 kms, when reading voltage on battery it increased when car was running. the more i think about it, it may be intermittent and I read it when it was working.
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    I recently had similar - replaced the 'module' in the alternator. It was easy as, and cost I think $60? Pretty easy to remove yours and check wear on the brushes.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    iaydemir's Avatar
    VY V6 Berlina
    May 2009
    Quote Originally Posted by Fletch_QLD View Post
    +1 for the above. If you cant be bothered replacing the brushes you can replace the whole regulator which comes with new brushes.
    This thread has a little more info -> Alternator warning light
  1. battery draining!!!!! NEED HELP!!!
    By my99ss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2010, 04:15 PM
  2. Something draining my battery!
    By holden_chik in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2008, 12:06 AM
  3. draining battery
    By whitey08 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2008, 01:37 PM
  4. Battery draining!!!
    By Pure Evil in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 01:02 PM
  5. battery draining.........
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2005, 03:15 PM
