Results 1 to 14 of 14
Thread: VY S I, fog lights plugged in but not working? wats next step? help !
    VY S
    Apr 2009
    ACT
    Unhappy VY S I, fog lights plugged in but not working? wats next step? help !
    hey guys
    I recently put fog lights into my commodore, the wiring was there i plugged them in but they arent working, i dont know what the next step should be? do i have to get a switch or is it just a missing fuse ? are they suppose to turn on automatically with the parkers?
    would appreciate your help thnx
    VY SS
    Jun 2006
    Albany
    you will need as headlight switch for the foglights like this
    COMMODORE VY VZ SS CALAIS INTERIOR HEADLIGHT FOG SWITCH (eBay item 300496625315 end time 24-Mar-11 14:09:28 AEDST) : Cars, Bikes, Boats
    the switch pulls back to turn the fogs on. you might also need to check if there is a spot in the fusebox for a fuse and relay
    VY SII HBD Calais L67
    Dec 2006
    Like said /\/\/\......a fog light enabled head light switch is needed. You will also need a relay to go in the blank hole in the relay box near the drivers side strut tower.
    VYII Calais L67
    S/C VX Calais
    Apr 2010
    canberra
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    make sure you check your grounding, my friend installed my fog lights then they stopped working the next day and all we did was changed the ground, mine have a seperate switch so i can turn mine on when ever i want
    S/C VX Calais
    Apr 2010
    canberra
    VY S
    Apr 2009
    ACT
    thnx guys for the help, didnt think they would be $77 !! -__- lol il probably check at wreckers see if they have them for cheaper
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    yeah ya could do that, or as others have said in making your own switch, its cheaper and better i think, as i did the same in my VY..
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Why use a seperate switch? Looks ugly and the only limitation of the factory switch is that you must have the parkers on to turn the fogs on (which is the law!).
    S/C VX Calais
    Apr 2010
    canberra
    VY Executive S2
    Jan 2010
    if you've got the wiring all there why would u use a seperate switch? just go to the wreckers and get one im sure they'll sell u one between 20-50 dollars
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    its only $77.... are you guys that tight LOL
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VY SS UTE
    Jan 2011
    SE QLD
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    WHATS!? about the law thing.. my fog lights when i brought them from the shop came with a a switch.. i stuck uner my head lights switch and i can turn them on when the car is off.. i dont need parkers on or anything, already been pulled over by the cops and they checked my car out, but they didnt say anything about the fog lights?
  1. VS Commodore manual/auto conversion wiring step by step instruction.
    By Beno1982 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2012, 08:59 AM
  2. vs v8 auto to manual conversion wiring step by step instrustions
    By cannibalrikman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2010, 03:48 PM
  3. Replies: 13
    Last Post: 12-06-2009, 09:10 PM
  4. Step By Step Guide for Replacing the Crank Angle Sensor (CAS) on an RB30
    By detox_nath83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-03-2009, 08:57 PM
  5. replace tail lights on a vx step by step
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2009, 07:28 PM
