Results 1 to 6 of 6
Thread: VY Calais Engine problem
    redlion05's Avatar
    redlion05 is offline Red Lion 05
    VY Calais Series 2
    Dec 2005
    Question VY Calais Engine problem
    Hello all.
    I own a VY Calais S2 with a 3.8L ecotec engine. Lately when i drive, my engine stalls (but i still have the electronics on i.e. radio, lights) and it takes 30secs-1min before I can start the car again. Also, it likes to cut off the engine at times but instantly ignite back to life a second after.
    This is a rare occourance and one that I can't show to a mechanic but can explain.
    Any suggestions on where the problem can be found? Many thanks in advance
    Vs Berlina
    Mar 2009
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    i figured it might be my crank angle sensor. I've had a similar instance with my old vn but i always like reassurance from others who might have a similar problem. Thanks for the head up
    vy berlina
    Nov 2010
    gold coast
    my vn did the same thing and we changed the crank sensor but accidently bent a tooth on the harmonic ballancer so we had to change both, id say crank angle sensor sounds most probable
    BakeTheTank's Avatar
    BakeTheTank is offline Phreddy-ed UP!
    VY S Series II
    Jan 2011
    Riverina NSW
    Honestly, have you been playing around with your airfilter? i had the same problem and all it was that my air filter hadnt actually been reconnected to the throttle body properly, and it was suffocating the engine.
    03 VY Berlina S1
    Jan 2007
    I had the same with my berlina a month ago. It was not the crank angle sensor replaced it. The problem was the computer underneath where all spark plug leads plug in can't remember the name but Holden wanted 400. I bought one from spare part shop for 100 same thing different brand
  1. 95 VR Calais - speedo/ dashboard light problem light problem
    By fseven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2010, 12:01 PM
  2. vs engine problem
    By antvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 03:21 PM
  3. Gts 355 big engine problem need help please
    By fat4s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2009, 07:13 PM
  4. vn engine fan problem
    By reaper01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2009, 07:35 PM
  5. VN Calais engine problem (and pics)
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2006, 05:06 PM
