Results 1 to 3 of 3
Thread: Adding Foot Well Lighing
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    Default Adding Foot Well Lighing
    what is.would be involved in adding footwell lighting to a VY S, I havent looked to see if there is any looms down there to do a quick addon, or is it a loom/fittings I`m going to have to buy/make
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I'm not sure about the S pacl but the Berlina/Calais already has front footwell lights, which is just a T10 globe fitted near the door side in each footwell. Depends on what kind of lighting you want to do.
    I have LED strips running in my lancer which i wired up by running a wire from the battery, though you can just use a 12v wire already in the car such as the cigarette lighter's power wire. Mount your strips, ground them, power them. Run parallel wires to the other footwells and repeat. I had them on a 3 way switch so I could control them like my cabin light. Door-Off-On. Have to wire the grounds to your door switches to do this though.
    However, in the Holden, I just replaced the T10 bulb to a blue high output one and will probably run wire from the front lights to the rear and just use SMD strips. Will cost about $10-$20 for the lights.
    If you want to get it professionally done. Talk to Phreddy from ASR. You can find him in the sponsors section.
    A Commodore is a passion. Anything else is just a car
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I ran mine to the interior light wire under the driver's scuff plate. First, though I pulled off the driver's side B pillar cover to see which colour wire it was, then found that wire under the scuff plates. The courtesy lights come on with doors open but not if I switch the interior light on manually with the switch. I think it was orange with white stripe or vice/versa.
  1. Vs putting my foot down and no go
    By adamrollo9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2009, 01:58 PM
  2. Right Foot and Brain
    By kowan in forum Jokes/Humour
    Last Post: 03-11-2007, 03:16 PM
  3. how to demerit on foot..
    By ssn8r in forum Jokes/Humour
    Last Post: 20-03-2006, 02:09 PM
  4. Leaking on my Foot!
    By majobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 10:52 AM
  5. The shoe is on the other foot now!
    By ElDubya in forum Jokes/Humour
    Last Post: 24-11-2005, 10:28 PM
