Hey guys,
I'm looking at getting a vy v6 manual sedan.
I've been looking and their is very little I'n the way of manuals and when you find one there stuffed and are expensive as.
Ive seen some good low k Vy autos for around $7000-$8500.
My question is am I not looking hard enough for a Vy manual? Or am
I better of with a auto and converting, what's needed for the conversion.
-gearbox
-pedal set up
- new tune
- some rewirng.
Does the getrag box just bolt up?
Is a new tailshaft needed?
your better off to just find a manual....
might take longer but soooo much easier
Chev badges are an instant fail
Get a factory manual.
There are quite a few on car sales from $12k to $17k for a "s"
definatley just find a manual one it will cost you more if you buy an auto and convert.
Will it really cost more?
Buy a decent Vy for 7500,
Then gearbox $500 - $1000
Pedal set up: $250
Other bits and peices: mounts ect $500
Which is still ten grand. I'll be doing all the work myself, all except for the re tune of the computer of course.
there is alot of differences in the electronics side of things between the two, its far easier to just buy a manual to start with, then you could buy an auto engine and re spec it with the manual ones parts should it blow up.
Something alot of people forget is that, Ecotec have different Cranks for manual/auto. The manual cranks have 2 extra holes for dowel pins, most people that do conversions dont worry about the dowels but in my opinion best to get dowel holes drilled into the crank. It is alot of stuffing around sometimes, so be weary if you want to do a conversion
Power is measured in DECIBEL
Yeah, VY Manuals are very hard to find, 1) with low kms, 2) in SA and 3) in good condition.
I was very lucky to find mine, purchased my '03 VY S pack manual back in January. It had done 116,000kms and had been extremely well taken care of. I paid $13K for it, but it was well worth the money.
Honest word, no scratches or dents on the body, interior was very clean too, just one small split on the factory head unit, but hardly a big issue. Immaculate condition.
Best of luck to you.
i got lucky with my rig aye, i was looking for a V6 manual and just by luck it was the first car that i actually had a look at on the weekend i got my money togetherDont regret buying a V6 at all
Yea I'd recommend just hanging out for a factory manual without a doubt, I picked mine up from the government auctions for $9,500 with 110,000km's on the clock and in immaculate condition...
Manual V6's can be really expensive as your paying a premium cause they are relatively rare and every P plater wants one! I didn't even look on carsales and what not when I was searching for mine cause I knew it wouldn't be worth it so I just kept actively looking at the auctions for about 3 months and quite a few popped up surprisingly!
I did a Manual Conversion on my VY V6 about 9 months ago it will cost a fair bit more then $2500 and i really suggest you know what your doing mine cost me as follows
Gearbox $900
Tail shaft $250
Clutch Pedal,Manual Gearbox Mount, Shifter assembly $330
Solid Flywheel,Exeddy Clutch and pressure plate $1300
Wiring Harness $100 (off eBay)
Master and Slave Cylinder $260 (new)
and i ended up spending about $600 on Random Bolts, Screw, Trims, Inspection Covers, Hydrolic lines, etc etc
It took me and a friend about 10 hours to do, having not done one before, after it was done i took it to my friends at holden and had them reflash the ECU to a manual program im not sure what they would charge for this service.
yeah just be careful when buying a manual s pack... wasnt really too careful with mine (being 19, dumb and really wanting a manual) and realised asfter i bought it that it had essentially been flogged as a burnout macnhine (found the service receipt hidden in the manual and back tires 90% worn front tyres 10% worn) and the engine blew up 4 months later
took it back even though it was out of warranty and they put a second hand engine in it and a new radiator for $250... i geuss im just a stubborn prick sometimes cause it took me 2 months to get that price lol
Thats the case for any manual car.
The fact that the rears where worse off than the fronts dosent realy mean it was a burn out machine, i have a VY manual and dont go around droping the clutch everywhere but i still need to change the rears and fronts at different times due to the IRS rear end..
