Results 1 to 3 of 3
Thread: Installing Climate Control.
    VY S Pac S2 & VZ V8 Calais
    Nov 2006
    Question Installing Climate Control.
    First of all I know a lot of people say not to do a climate control conversion but i am just wanting to know how to do it and maybe later on try it.
    I have a vy series 2 commodore with normal heater controls. What is invovled in converting it to either single or dual zone climate. I know the heater box, heater controls and wiring need to be changed but how hard would that be. Can the new wiring just be intergrated into the current wiring of the car?? I know there is a sensor clipped onto the front radiator, does that just run stright back to the climate control facia or is the BCM invovled. I have a spare heater box, climate control facia, wiring and sensors, is there anything else i need.
    Thanks Mccar13
    VY s m5 supercharged
    Aug 2008
    The BCM is different you need a High or Lux BCM and the wiring to go with.
    There are also some solenoids and to access it all the whole dash needs to come out.
    If you have the dash out for what ever reasion it would not be tht hard to swap it all over but taking the dash out just for climate is a big job for a small gain.
    I have had a quick look at the wiring pics for a VY to try and find a short cut when i wanted to do it for my car but there are quite a few different things.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Yep you need the Berlina/Calais BCM and associated wiring. The main difference is that the climate control unit is connected to the BCM with a data link. On the manual control models its just a bunch of switches and analog connections to the BCM.
    As far as i can see its connected on the same loom as the ABS/TCS module. Other then that, everything seems to be connected straight to the climate control unit.
  1. Installing a digital climate control
    By Kall911 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2012, 07:38 PM
  2. Installing Climate Control
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2006, 10:14 AM
  3. Installing Climate control
    By kingj133 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2006, 10:13 AM
  4. help Installing a digital climate control
    By Kall911 in forum Electrical Wiring / Questions
    Last Post: 26-08-2005, 08:01 PM
  5. Installing VX climate control
    By Black VXS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-06-2005, 09:04 AM
