Results 1 to 6 of 6
Thread: Dyno tune or not
    VY V6
    Sep 2008
    Default Dyno tune or not
    Hi just wondering if a flash tune / dyno would help or give me more power as I have put mods on the car but am I getting the full benefits & does the factory ecu adapt or keep resetting back to standard settings?
    Here are the engine mods
    Hi mate as per our telephone call today in regards to a dyno tune on my VY V6 I have listed the mods below.
    The car has
    Cold Air Induction second inlet picking air from behind the left hand head light (fully sectioned off from engine bay) with standard air box with K&N flat filter.
    Pacemaker extractors
    2.5 Cat back exhaust system
    70mm Throttle Body
    Lower Plenum Spacer 24mm
    Regards
    Col Beever
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    dyno tune FTW!!
    even road tunes are better.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VY 03
    Aug 2005
    I have been told by 2 tuners "no" One said something about it being locked but i could send holden my vin and get a rejection code or some bs. But i think from memory user delcowizard can do it some how?
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    It can be done, I'm pretty sure the VY ECU is the same as the VX. My VX has been tuned but its costly. Frankly you haven't modded it enough to bother with a tune, a cam or at least some higher ratio rockers, otherwise your ECU can handle your current mods. You will spend upwards of $1k for a handful of kilowatts.
    Ronald Reagan (1986)
    VY s m5 supercharged
    Aug 2008
    Quote Originally Posted by acarmody View Post
    The VY computers are different to the VX.
    There are only a hand full of tuners that can tune these computers and you will be looking at $1200 min. As stated you dont realy have the mods to need a tune and would be a wast of you time and money.
    Unless you plan to fit a cam there is no need for a tune, even if you get some rockers a tune will still not be needed. Yes you will get a small amount of power but worth it.
    If you do realy still want a tune then Dick in NSW it the person to see.
    VY SII HBD Calais L67
    Dec 2006
    VY&&&, it depends on how far you are going if you tune or not. If that's all you are doing and you aren't happy then a tune may bring it all together better but it won't give you more than 10rwkw and a few Nm extra on the stock cam. You could drop a wad and cam it but it will still only go as hard as the amount of air it can "suck" in so really not worth $1200 imo.
    A tip...........ditch that 70mm throttle body and go back to the stocker. If the car is an auto you may notice some weird stuff here and there and this can be fixed up in the tune though
    VYII Calais L67
  1. Dyno Tune VR SS
    By Rusty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2011, 01:39 AM
  2. Dyno tune help!
    By glenny1988 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-08-2010, 10:29 AM
  3. [WA] Dyno tune
    By Frank_vr in forum Tuning
    Last Post: 25-07-2010, 02:19 PM
  4. dyno tune
    By riss in forum V8 Development and Modification
    Last Post: 24-11-2005, 08:20 AM
  5. where to dyno-tune?
    By mara in forum General
    Last Post: 31-05-2005, 11:51 AM
