hi all, I am changing the water pump in my vy ss, just wondering when refilling it back up with coolant, how do I make sure there is no air in the radiator, I'm use to doin a v6 as they have a bleeder screw, some info on how I'm suppose to refill the cooling system to make sure of no air and what else I need to know, cheers in advance for help
just fill up the coolant reservoir on the passenger side strut tower, because its higher than the radiator and motor the air bleeds itself out once the thermostats fully open
oh ok cheers for that, also when putting the water pump back on do I need to put water proof sealant on the gaskets or should it be right, all the help on the steps of re installing the water pump would be greatly appreciated, thanks
Sealant isnt neccessary but certainly wont hurt, we usually chuck some on and it helps keep the gaskets in place when putting the new pump on.
Silver Certified.
thanks for that mate, I haven't got any sealant but I have some loctite will a little but of that be ok just to hold the gaskets in place
Loctite may actually cause it to leak as it dries differently to sealant.
A tube of sealant should be pretty cheap just tell them what its for and you should get the right stuff...
Silver Certified.
You need to use a non hardening sealant so, so it cannot crack and then cause future leaks, i use it on any paper gasket as i found they just never quite seal.
cheers guys thanks for all the help, I should be able to get a tube from super cheap wouldn't I
