Results 1 to 3 of 3
Thread: what do i need to fit cruize controll to my vy Series 1 ute
    vy commodore ute
    Mar 2011
    ballarat
    Default what do i need to fit cruize controll to my vy Series 1 ute
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Your standard ute BCM should support cruise, so, you'll need the cruise control module/stepper motor, throttle linkage cable, a vx s2-vz cruise indicator stalk and the secondardy brake stop light switch. Have a close look around the drivers side strut top where the module mounts. In this area you should find the cruise module plug in the original harness taped back and unused somewhere. You'll probably also need to add a fuse in the fuse panel where cruise usually is.
    Hope that helps,
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    and depending of your cars a manual or automatic, you will need some extra bits for the clutch pedal!
  1. Controll arms
    By SUSVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2011, 09:54 AM
  2. VP Cruise controll
    By discostuee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2008, 03:58 PM
  3. cruse controll
    By ssmartie2001 in forum Electrical Wiring / Questions
    Last Post: 05-12-2005, 07:30 AM
  4. Curise Controll Help
    By seabass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2005, 11:06 AM
  5. Climat controll
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 05:44 PM
