Results 1 to 7 of 7
Thread: VY commodore ABS issue
    VY Commodore
    Apr 2011
    Mackay
    Default VY commodore ABS issue
    Guys
    Wondering if anyone can help me out with this one.
    Currently have a mechanic looking at my Vy with an ABS issue. ABS has been disabled and so has traction control. ABS light remains on in the dash. Have checked all speed sensors, have even replaced suspect ones, all wiring checks out and also have swapped ABS module out with another one. Cleaned all required connections as well....
    The mechanic now tells me he has had an auto elec look at it and reckons its the cluster module?....sounds like a crock of sh!t to me, as he now reckons i have to change out the complete instrument cluster. Cant find a detailed schematic for this. My understanding is the ABS is talking to the ECM/ECU which then shows any issues on the cluster, as the cluster basically acts as a "monitor" for any issues from sensors and the like sending to the ECU.
    Any suggestions would be good.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    are you running same size wheels and tyers font and back that can cause all sorts of problems. but the truble codes would help i dont think it would be in the dash
    VY Commodore
    Apr 2011
    Mackay
    there were 19s on it however i have jus put the standard 15 alloys back on due to the amount of pot holes up here
    as far as codes go, it was showing up right hand side front and rear sensors. both checked out ok. i even replaced them jus to be sure. when the mechanic took the car for a spin all 4 speed sensors were all over the place..at first they were showing the usual acceleration graph. however then they then went ape shit, not jus on the right hand side but the left as well, spiking all over the place, and then one of the left hand side one wasnt showing an form of acceleration at all.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'd be checking a couple of things, make sure all the connections to the sensors are making good contact, make sure all your earths are tight and make sure the battery terminals are clean and tight as well.
    Visit my Facebook page
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    2003 VY s pac supercharged
    Jul 2010
    I use to have a 2005 VZ executive, and the abs light use to come on all the time, my mechain checked the sensors on the wheels which were dirty and then used a hand held computer to wipe the cars memory of the abs alerts. The abs light didnt come on for about 3 months and then came on again in which he suggested to replace sensors, (which arnt cheap). At the end of the day mate, your brakes are fine, its just that the ABS sensors are overly sensative. \
    - Keep your sensors clean, and get the mechanic to wipe the computer for any alerts and thats all you can do without spending big bucks.
    Hope this helped
  1. VY Commodore Cig Lighter issue
    By haboob in forum Electrical Wiring / Questions
    Last Post: 10-07-2010, 05:33 PM
  2. VX Commodore Issue
    By WinterVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2010, 03:21 PM
  3. VX Commodore deadlock issue
    By rickburt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2009, 09:54 PM
  4. VT Commodore Starting issue
    By hitman1979 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2008, 10:00 AM
  5. 95 VS Commodore Executive Issue
    By commodoreant75 in forum Electrical Wiring / Questions
    Last Post: 05-10-2007, 03:10 AM
