Results 1 to 21 of 21
Thread: VY car antenna replacement
    2003 VY s pac supercharged
    Jul 2010
    Default VY car antenna replacement
    Hi,
    Has anyone ever replaced the car antenna on a 2003 VY series 2 s pac?
    I was wanting to replace the ugly long motorised antenna with a short black stubby one. Does anyone know if this is possible on the VY holdens?
    cheers
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    I have done this on a number of my previous cars - and plan to do it on my VY in the near future. I see no reason why it can't be done, but getting it to sit flush on the panel may involve some lateral thinking as it's a small hole on a tight curve - compared to some I have done.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    Jul 2010
    ok, do i need to remove the whole antenna assembly? or does the antenna mast twist off? and i twist the smaller stubby antenna on?
    Jun 2005
    Brisbane Bayside
    it's harder than just twisting it off.
    Jack up front passenger side of car
    remove wheel
    remove plastic cover insider wheel arch
    remove aerial from up under here
    insert hew aerial base from under wheel arch
    screw new aerial to base from above.
    The tricky part is that the generic rubber aerials are designed to be fitted to flat surfaces - not curved.
    so adaptations to the base are required to get a good fit as the aerial hole is on a curved part of the panel on the vy.
    I'll see about taking some photos if I get a worthwhile result on mine.
    Jul 2010
    yer a picture would be great! ok i see, must take some crafty skill to get it looking flush. nothings ever as simple as screw off screw on is it haha!
    VY S Series 2
    May 2010
    i think i might still have the instructions from when i changed mine... if so ill put it up for you but you need to remove some interior stuff as well to diconnect the aerial
    Jun 2005
    Brisbane Bayside
    It actually worked out easier than I thought. Once the old aerial is removed - the standard issue plastic trim stays and the new rubber aerial fits through that.
    Gone is the clunky, oversized fragile and overly expensive unit - in is the sleek 'n' sexy rubber aerial. Reception is a lottle better than the old aerial - but far from perfect. It would need to be perfect before I would switch from listening to the ipod, but that's a whole 'nother issue.
    Anyways, aerpro universal mount rubber aerial $13 and supercheap. Remove old aerial, dissassemble the rubber aerial - the base goes up under the wheel arch, the aerial screws into the base from above - clamping either side of the standard plastic trim. I also earthed the aerial via a wire - but I don't know if it makes any difference?
    Attached Thumbnails Attached Thumbnails VY car antenna replacement-1.jpg   VY car antenna replacement-2.jpg   VY car antenna replacement-3.jpg   VY car antenna replacement-4.jpg
    Jul 2010
    yer the standard aerial is around $160 from holden, what a waste of money. is there any particular brand of stubby antenna that i need to use? or lets say one off ebay would do the trick?
    Jun 2005
    Brisbane Bayside
    Can't speak for random brands off ebay - but in principal you should be able to work something out with any universal aerial ?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by jdcasagrande View Post
    Only about $70 for a replacement mast/rope if it gets bent. No need to replace the aerial motor in such an accident.
    Jun 2005
    Brisbane Bayside
    'only' $70
    I have replaced my fully functional automatic aerial with a $12 rubber one for aesthetics - not just the visual but that clunky noise it makes irritates me.
    Next step is to put the old one up on ebay I suppose.
    00 SS M6/79 chev Monza
    Mar 2005
    thanks for the tip ,changed mine today .....way way better than the bent and twisted non working electric version i had in there !!
    Jun 2005
    Brisbane Bayside
    Enjoy
    I found out today - at 110kmh it lays down pretty flat.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Fletch_QLD View Post
    'only' $70
    They only cliunk when the rope gets stripped, the clunk noise is the gear skipping teeth.
    Silver Certified.
  15. #15
    Mar 2005
    Quote Originally Posted by RiCeY View Post
    who cares ...the rubber one functions well and looks better
  16. #16
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Post a pic on the car Im not convinced, especially if it cant even stay upright at freeway speeds.
    Silver Certified.
  17. #17
    Jun 2005
    Brisbane Bayside
    Nah mate - it's not that it can't stay upright - it automatically lays down to reduce friction at higher speeds
    Best pic I can manage at the moment - not that I want to convince anyone. I love it. I'll look at taking a better photo tomorrow.
    Attached Thumbnails Attached Thumbnails VY car antenna replacement-aerial.jpg
  18. #18
    VY
    Feb 2009
    i started another thread but I'll ask here.
    My clunky VY aerial just failed a roadworthy for the gear skipping teeth Does that sound right?
    Anyway, if it is, I'll go the $13 supercheap route, so thanks for the post
  19. #19
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    idk bout u but my arial doesnt go up or down, i had to pull it up so i just left it at about a quarter up
  20. #20
    Jun 2005
    Brisbane Bayside
    That's crazy that an aerial becomes a roadworthy issue - I guess that means they couldn't find anything else?
    How much did they quote to replace it?
  21. #21
    VY SS UTE
    Jan 2011
    SE QLD
    That's outrageous mate.
  1. antenna replacement on a VL
    By crashnburn1979 in forum ASR Audio & Electronics
    Last Post: 22-07-2009, 12:24 PM
  2. VZ Antenna Replacement
    By royincairns in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-06-2009, 01:18 PM
  3. vt manual antenna replacement
    By execvt in forum Electrical Wiring / Questions
    Last Post: 04-04-2007, 09:57 AM
  4. Antenna Replacement
    By Murmur77 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2006, 07:26 PM
