Hey guys,
We'll I was doing my stereo for the first time and wired all the RCA's down the left side (took a bit but i released you could pop out the bit on the skirt to show the 4 torques, then when you lift it there's the screw for the kick panel).
I've now tried with the right side while doing the kick panel, i unscrewed it under the skirt and I don't know how to get it off or if it's lached on a bracket or stuck on the bonnet release bit.
I didn't look for longer than 10 minutes as I was ####ing around all day learning how the back seats came out and how to wire it all up..
Any help would be awesome.
Ps. Power and amp leads can run down the same side right??
there should be another torx screw near the bonnet release handle
they can buy i believe it leads to distortion in the speakers from interference. i ran mine on opposite sides to be safe.
livin' the low life.
yep run rca's opposite side to your main power cable from the battery
