Results 1 to 4 of 4
Thread: Climate control
    Vy 5.7 one tonner
    Apr 2011
    Darkan
    Default Climate control
    Hi guys I was wondering if it is possible to install climate control into a series 2 vy from an ss or something and if so what does it take? Cheers
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Mate,
    This is one of the more commonly desired upgrades - but few attempt it. My hat goes off to those who do it - most of them reckon they wouldn't do it again.
    You need to remove most of the dash - this involves degassing/disconnecting/reconnecting/regassing the a/c refgrigerant.
    Swap heater box, swap cable controlled actuators for vacuum controlled actuators - if that part doesn't phase you, you'd be almost half way there.
    You need to upgrade the bcm and install matching harness (It may be possible to patch existing harness in to upgraded bcm?)
    as well as the vacuum actuators there is the solenoid controller and temp/light sensors.
    When it comes to fitting the electronic control panel you will need different fascia pieces (control panels are not straight swap) - of course you could take the opportunity to fit the flip out cup holders...
    It's a huge job that will cost you $$ even if you do all the work yourself.
    Climate control does rock though
    but imho the cup holders are fail ...
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    Vy 5.7 one tonner
    Apr 2011
    Darkan
    Thanks man. Doesn't look like I'll be doing it anytime soon. I suppose u would be looking around 3 or 4 grand to be done by an aircon joint?
    Jun 2005
    Brisbane Bayside
    I seem to recall someone saying they were quoted $2k labour only to do a VX but that was years ago. Most places quote a days labour just to remove the dash.
  1. [VIC] vr vs climate control heater box and climate control panel.
    By python_hunter1 in forum Parts And Other Items For Sale
    Last Post: 25-03-2011, 08:50 PM
  2. climate control,how does it work need to know for climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2010, 12:49 PM
  3. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  4. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  5. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
