Results 1 to 3 of 3
Thread: ABS Suddenly has a fault...
    VY EXECUTIVE Series II
    Feb 2010
    Default ABS Suddenly has a fault...
    Hi all
    Been looking around but this question doesn't look like to be answered on this forum :/
    Coming home tonight (Perth is currently raining )
    Powershift "ON" select first gear and off the lights got the wheels spinning bouncing the revs between 4500 - 5500, select 2nd and speedo shows 110 - 120
    Once it got to those speeds all of a sudden the dash said "ABS fault" and the abs light is now constantly lit
    So I continue to drive home going 70kmph hit the brakes and I have no ABS ??
    Can some PLEASE explain how does ABS interfere with the wheels spinning? I have done this before MANY times yet this is the first ive had an ABS fault
    Any answers or ideas would be MUCHLY appreciated
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    What codes are up? It may just be time where a sensor/unit has failed?? ABS (Anti-lock Braking System) Is just that.. It pulses individual/all wheels that are detected to be out of sync under breaking (speed, tyre rotation) or if a certain pedal depression pressure is reached.
    Disconnect batt and remove and reseat the harness to the ABS module.. Fault codes won't be removed
    Cheers,
    Dave
    Feb 2010
    Cheers Dave found the solution... no codes came up just disconnected the battery for 1 hour went for a drive and light went off
    But no the brake pedal was never depressed at the time.
  1. Car Stalls suddenly on LPG. Starts again straight away.
    By BerlinaBen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2011, 08:25 AM
  2. Power Windows suddenly stopped
    By daver00 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2010, 08:08 AM
  3. Vt suddenly cuts off????
    By 11gothevt11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2010, 08:08 AM
  4. VT just suddenly died
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-12-2008, 08:03 PM
  5. car has suddenly gotten warmer
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2006, 02:04 PM
