Results 1 to 8 of 8
Thread: VY 25th Anniversary - LED Tail lights and cruise control not working
    VY 25th Anniversary
    Jan 2011
    Swan Hill VIC
    Default VY 25th Anniversary - LED Tail lights and cruise control not working
    Hi all, first post on the forums, but have been lurking since I purchased my commodore back in September.
    Yesterday I fitted some smoked LED altezza tail lights.
    They work fine and look great, no errors on the dash and indicators, driving lights, brake lights and reverse lights all work fine and as expected.
    Only problem I am having is that on the way to work this morning I went to use the cruise control and it doesn't work at all. I spoke to the local mechanic and he seems to think the LED lights will be causing a voltage change that the cruise uses.
    Has anyone had this problem or a similar one before? Is there some resistor or something I need to put into the taillight assembly to balance the voltage?
    Cheers,
    Jono
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    ..u checked the fuse right?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Because the LED draw less current it isnt recognised by the cruise control as braking.. so when you hit the brake the cruise control gets confused..
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VY 25th Anniversary
    Jan 2011
    Swan Hill VIC
    Fuse has been checked, and just to be sure it is the lights, I swapped the old ones back in with normal globes rather than the LED board and wholla it just started working again.
    So I think it is something to do with the brake sensor/cruise but no idea where to go from here.
    VY 25th Anniversary
    Jan 2011
    Swan Hill VIC
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    when i fitted led brake/parker globes to my vy i had the same problem and was told that because the leds use less power it sends a different signal to the computer (basicly everything electrical goes through the computer) and that messes stuff (like cruise control and traction control in my case) so i just use normal globes now
    if you want to get it working then try and add a normal brake/parker globe into the circut and that might work
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
    VY 25th Anniversary
    Jan 2011
    Swan Hill VIC
    Yeah I'm probably going to put a resistor in their with the same resistance.
    I'm waiting on a third eye level brake kit to go in the back window as I took my spoiler off. So I'll probably just wire it in when I do that. For now I'll go without cruise.
    2000 VU S pack Ute (Red goes faster)
    Nov 2008
    Bonnells Bay NSW
    Quote Originally Posted by D3CID3R View Post
    It's not because it draws less current or has less resistance on the circuit,
    The reason your cruise control turns off is because turning your tail lights on uses the same LED diodes as if you were pressing the brake.
    Just delivers less power to them, but it sends that same feedback on the brake pedal line that the cruise control system is looking for to turn itself off.
    The only way to fix it is to put a relay before both tail lights and find another +12v source.
    Too much effort as far as im concerned.
  1. VT cruise Control not working after lights turned on
    By Legman_oz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2012, 03:46 PM
  2. My VY II 25th Anniversary
    By fourstar82 in forum VY - VZ - WK - WL - V2
    Last Post: 27-04-2010, 03:22 AM
  3. [SA] FS: VY SII 25th anniversary V6 Gas
    By GLITRES in forum Vehicles For Sale
    Last Post: 16-02-2010, 12:32 PM
  4. LED tail lights made T/C and Cruise control die?
    By greggy85 in forum Electrical Wiring / Questions
    Last Post: 08-04-2009, 08:47 PM
